- 10,318
- 1,489
I had a thought that I wanted to share in another thread, but it wandered way off track and quite properly was closed. But I thought the separate idea that I had spawned from the old thread was worthy of posting in a new thread. I do not want to re-open the old thread, though!
In flat space-time, the relation E=mc^2 is a special case of the more general relation
$$E^2 - (pc)^2 = (m\,c^2)^2$$
i.e. when p=0, ##E=mc^2##. Here E is the energy, p is the momentum, c is the speed of light, and m is the invariant mass, which happens to be equal to the relativistic mass when p=0.
It will be convenient to re-write this so that everything is dimensionless by dividing both sided by ##m^2 c^4##. This gives.
$$\left(\frac{E}{m c^2} \right)^2 - \left(\frac{p}{mc} \right)^2 = 1$$
There's a similar relationship in the curved space-time of the Schwarzschild geometry, which represents a single, massive, non-rotating gravitating body. In the same dimensionless form, and for purely radial motion, this is:
$$\left(\frac{E}{mc^2}\right)^2 - \left(\frac{dr}{d\tau} / c \right)^2 = 1-\frac{r_s}{r}$$
Here E is what's knowing as the "Energy at inifinity", a conserved constant for an object free-falling (i.e following a geodesic) in the Scwarzschild spacetime. ##r_s## is the Schwarzschild radius, and r is the Schwarzschild radial coordinate. This comes from "orbits in strongly curved spacetime", https://www.fourmilab.ch/gravitation/orbits/, which is basically a publically available summary of some results from MTW"s textbook "Gravitation". I've converted the original notation to replace ##\tilde{E}## with E/m, and made other changes as needed to deal with the issue of the original source using geometric units. I've also set the angular momentum L to zero.
If we set ##dr/d\tau = 0##, we see that we now have
$$\left(\frac{E}{mc^2} \right)= 1-\frac{r_s}{r}$$
or
$$ E = \sqrt{1-\frac{r_s}{r}} \, m c^2$$
Note that as r approaches r_s, E , the "energy at infinity", approaches zero.
For the reasons stated, this could be regarded as a sort of curved space-time equivalent to "E=mc^2".
or
