Energy Intensity of black coal
In summary, the emissions intensity of burning brown coal with an energy content of 16 MJ/kg and a carbon content of 65% in a 30% efficient steam power plant is 1.79 kgCO2/Kwh. This is higher than the emissions intensity of Hazelwood, which is 1.53 tCO2/Mwh.
Jonski
42
Brown coal, energy content 16 MJ/kg, carbon content 65% by weight, burning in a 30% efficient steam power plant.
What is the emissions intensity (kg CO2 emitted/kWh delivered) ?
Compare this to Hazelwood which is 1.53 tCO2/Mwh
3. The Attempt at a Solution
I really have no idea how to do this question but this is what I tried
I have done a bit of research and worked out that 1kg of carbon = 3.67kg of CO2, so 0.65kg of carbon = 2.39kg of CO2. (1kg * 65%)
The energy produced is also 16MJ * 30% = 4.8MJ
4.8MJ = 1.3 Kwh
so the emissions intensity is 2.39/1.3 = 1.79 kgCO2/Kwh ?
...energy content 16 MJ/kg, carbon content 65% by weight, burning in a 30% efficient steam power plant..
So if 1kg burns it produces 16x .3 MJ = 4.8 MJ ...1Kw Hr= 3600 K J ... so IKg coal produces 1.333333 KWHrs
This Kg of coal contains 650 gms of carbon ...C... At Wt= 12 ...O At Wt 16 so 12 gms of C makes 44gms CO2
So 650 gms C(1 Kg coal) burns to 2.383 Kg CO2 producing 1.3333KwHrs 1.787Kg CO2 per Kw Hr.
Likes Jonski
Related to Energy Intensity of black coal
What is the definition of Energy Intensity of black coal?
The Energy Intensity of black coal refers to the amount of energy that can be obtained from a specific unit of black coal, typically measured in joules per kilogram (J/kg). It is a measure of the efficiency of converting black coal into usable energy.
How is the Energy Intensity of black coal calculated?
The Energy Intensity of black coal is calculated by dividing the total energy content of a unit of black coal by its weight. This can be determined through various methods such as proximate analysis, ultimate analysis, and direct calorimetry.
What factors affect the Energy Intensity of black coal?
The Energy Intensity of black coal is influenced by various factors such as the quality and type of coal, the mining and processing methods used, and the efficiency of the power plants where it is used. Environmental factors such as air pollution control measures can also impact the energy intensity of black coal.
How does the Energy Intensity of black coal compare to other energy sources?
The Energy Intensity of black coal is relatively high compared to other fossil fuels such as natural gas and oil. However, it is still considered to be a more efficient and cost-effective energy source compared to renewable sources like wind and solar power.
Can the Energy Intensity of black coal be improved?
Yes, the Energy Intensity of black coal can be improved through technological advancements and the development of more efficient and cleaner coal-burning technologies. Additionally, implementing energy conservation measures and utilizing coal in combined heat and power plants can also help reduce the energy intensity of black coal.
  • Materials and Chemical Engineering
18K
