Energy level transition questions
In summary, for a simple hydrogen atom, it is possible for an electron to jump from energy level n=5 to n=3 or n=2 or n=1, releasing 3 photons with their respective specific frequencies/energies. However, the probability of this happening is significantly lower compared to the electron jumping directly from n=5 to n=1, due to selection rules and the strength of the electromagnetic interaction.
Masonn
Say for a simple hydrogen atom, an electron absorbs just the right amount of energy such that it jumps up from energy levels n = 1 to n = 5. When it comes back down, is it possible to say, do n = 5 to n =3 to n = 2 to n =1, releasing 3 photons with their respective specific frequencies/energies? Or is it only able to go from n = 5 to n = 1? And why?
Thanks in advance.
It's not a homework question, it's a question that came out of a classroom discussion.
Emission and absorption of photons from an electron is described by quantum electrodynamics, called QED for short. This is an example of a quantum field theory and to properly describe the transitions in hydrogen would require a lot of background and technology. But we can get some qualitative information out using some information that requires a bit of quantum mechanics knowledge and some intuition.
Basically, the important idea is that the strength of the electromagnetic interaction is proportional to the electric charge, ##e##. The amplitude for a single photon transition is then proportional to ##e##, so the probability of a single photon transition is proportional to ##e^2##. Since the value of the electric charge depends on the system of units that we use, it turns out to be a much simpler to express this in terms of the dimensionless fine structure constant
$$\alpha = \frac{e^2}{4\pi \epsilon_0 \hbar c} \sim \frac{1}{137}.$$
So we can as well say that the probability for the emission of a single photon carries a factor of ##\alpha##.
Now suppose there is a particular transition from n=5 to n=1 that satisfies the angular momentum selection rules that Jolb pointed out. This transition can indeed proceed by the emission of 2 photons, but the probability of this happening is now proportional to ##\alpha^2##, so it is roughly 100 times less likely than the single photon transition. Similarly, the probability for the 3 photon transition will be proportional to ##\alpha^3##, so it is 10000 times less likely than the single photon transition.
Multiphoton transitions have indeed been observed and in fact allow certain transitions that are forbidden from occurring via a single photon transition by the selection rules. An important example is the 2s to 1s transition in hydrogen.
FAQ: Energy level transition questions
What is an energy level transition?
An energy level transition is the movement of an electron from one energy level to another within an atom. This can occur when the electron absorbs or emits energy in the form of light or heat.
What causes an energy level transition?
An energy level transition is caused by the absorption or emission of energy by an electron. This can happen through various processes such as absorption of light, collisions with other particles, or interactions with magnetic fields.
How are energy level transitions related to atomic spectra?
Energy level transitions are directly related to atomic spectra. When an electron moves from a higher energy level to a lower one, it emits energy in the form of light. This emitted light creates the unique spectral lines that are used to identify elements.
Can energy level transitions occur in molecules?
Yes, energy level transitions can occur in molecules as well as atoms. In molecules, the energy levels are more complex and are influenced by the bonding and arrangement of atoms. This results in a wider range of energy level transitions and spectral patterns.
How are energy level transitions important in everyday life?
Energy level transitions are important in many aspects of everyday life. They play a key role in technologies such as lasers, LED lights, and solar panels. They also help us understand the properties and behavior of matter on the atomic and molecular level.
