Energy lost by EM radiation per cm in air?
In summary: It's good that you have experience with UKW tools. They can help you calculate path loss for frequencies up to 24GHz.
NotASmurf
150
Hey all, is there a formula that can calculate the energy losy by a photon traveling through air at 1 atm per meter given frequency? Any help apreciated.
Science news on Phys.org
Photons do not lose energy when traveling - they are what they are.
However, a photon may be absorbed and cease to exist.
Do you have a particular frequency range in mind? (radio, visible, X-ray, gamma-ray, ...?)
If you google "atmospheric absorption" you may find out what you want. Your question is too unspecific for us to help you more.
Perhaps you are not concerned with a single photon?
Yea, but wouldn't it be absorbed and reemitted at lower energy on average a certain number of times or would that be too capricious to be used?
Yea, microwave/radio
So you are interested in radio wave propagation. There is loads of information about that and I recommend that you google appropriately to get some background and to find out the actual questions that need answering for your problem.
The attenuation of the atmosphere varies wildly over the microwave region and also with water content. There isn't a number of formula that you can just plug into and get a reliable answer. There is a lot of Statistics involved. But there are many graphs (google Images) which could give you a clue about what to expect.
Likes NotASmurf
as you have been told ... forget about individual atoms ... that's irrelevant
ohhh and for the calc's below, anything less than a few 10's of metres is also going to be irrelevant
as you would be dealing with near field effects which is isn't going to be helpful to you
if you want to learn more on that google RF propagation, near field and far field
NotASmurf said:
...... Yea, microwave/radio
OK that is relatively straightforward and is used all the time for us doing pathloss calculations between radio transmit and receive sites
say example microwave links
have a look at this site and it tells you all about FSPL ... Free Space Path Loss
http://www.radio-electronics.com/info/propagation/path-loss/free-space-formula-equation.php
This will serve well for line of sight paths and for frequencies up into the mid freq microwave bands ~ 10 GHz
after 10GHz. there are additional significant atmospheric problems to deal withcheers
Dave
Likes NotASmurf
You should try to find stuff on 'Link Budgets". That takes everything into account; transmit power, feeder loss, antenna gain, path loss, spreading loss, etc etc and can give you a Carrier to noise ratio for the demodulated signal. Just what a chap needs. Path loss on its own is not actually a lot of use for designing a practical system.
the 2 popular ones are Radio Mobile and UKW Tools
I have used UKW tools for many years for my activities on 1296MHz and up to 24GHz
it takes all those factors into account :smile:Dave
Likes sophiecentaur
FAQ: Energy lost by EM radiation per cm in air?
What is EM radiation?
EM radiation, also known as electromagnetic radiation, is a form of energy that is emitted by charged particles as they move through space. It includes a wide range of wavelengths, from gamma rays and X-rays to radio waves and microwaves.
How is energy lost by EM radiation measured per cm in air?
The energy lost by EM radiation per cm in air is typically measured in units of joules per centimeter (J/cm) or watts per square centimeter (W/cm²). This measurement is known as the radiation intensity and is used to quantify the amount of energy that is absorbed or transmitted by a material.
What factors affect the amount of energy lost by EM radiation per cm in air?
The amount of energy lost by EM radiation per cm in air can be affected by various factors, such as the type and intensity of the radiation, the distance the radiation travels, and the properties of the medium it travels through (e.g. air, water, or a solid material).
How does the energy lost by EM radiation per cm in air impact living organisms?
The impact of energy lost by EM radiation per cm in air on living organisms depends on the type and intensity of the radiation. High levels of radiation can be harmful to living cells and tissues, causing damage to DNA and potentially leading to health problems such as cancer. However, certain forms of radiation, such as ultraviolet light, are also essential for life as they play a role in processes such as photosynthesis.
Can energy lost by EM radiation per cm in air be recovered?
The energy lost by EM radiation per cm in air can be recovered to some extent through various processes, such as reflection, refraction, and absorption. However, some of the energy will also be dissipated as heat, which cannot be recovered. The extent of energy recovery depends on the properties of the material the radiation interacts with.
18K
