Exploring Energy-Mass Equivalence: Converting Energy to Matter in Everyday Life?
In summary: Basically, mass and energy are related in a very special way, and there's no physical law that says you have to add up the mass of all the particles in a system to get the total mass of the system. In fact, if you take the total mass of the system and divide it by the mass of the nucleus of the heaviest atom in the system, you'll get a number that's about half the mass of the nucleus of the heaviest atom in the system.When we charge a phone battery, its mass (weight) increases according to E=mc2 . Does it mean we convert energy to matter? If not, how its mass increases?Yes
Ebi Rogha
24
a) Can we convert energy to mass (matter) in every day life?
b) When we charge a phone battery, its mass (weight) increases according to E=mc2 . Does it mean we convert energy to matter? If not, how its mass increases?
Yes, energy stored in a system contributes to its mass. Whether there is any conversion going on is a matter of terminology.
Mass and matter are different things. Mass is a property of matter, but matter also has many other properties, such as spin and charge.
Charging a battery does not involve converting energy into matter. The mass of the battery is increased by rearranging the existing particles into a different internal configuration. The mass of the battery is not merely the sum of the masses of the particles but also depends on their configuration, so the mass of the battery changes without adding or removing particles (ideally) but simply by changing their configuration.
Likes cianfa72, Ebi Rogha, PeterDonis and 3 others
Mass is defined as energy measured in COM frame of reference where total momentum is zero. If such COM system does not exist, there is no defined mass but energy, e.g. a photon.
An electron and a positron pair, we may say they are matter, is generated from two photons. These photons have energy and also mass because two photon have their COM frame of reference. Mass keep existing before and after the reaction. So we know when the final state has material, both energy and mass are conserved before and after. I do not think chemists would admit two photons are material.
When you charge battery chemical state of the battery changes. When you warm battery its molecules do more thermal motion.
Energy and mass increase in both. Although molecular configuration or motion change, the number of molecules do not change.
I do not think chemists say material increase in both the cases.
[EDIT]
Though there is no such COM frame of reference, zero mass is assigned to a photon particle because its dispersion relation ##E=pc## is included in general relation ##E^2=p^2c^2+m^2c^4##.
Likes vanhees71
That's rest mass. There is also invariant mass of a system, which is conserved generally - e.g. where the system consists of a material object and a photon, which is absorbed.
You need a lot of energy to create a significant amount of mass. You need very little mass to create a very large amount of energy (as evidenced by the atomic bombs). When measuring the mass of a system, for extremely accurate measurements it is necessary to take the energy into account.
Fun fact: Most of the mass in your body is just energy stored in the quarks in the protons and neutrons in the atoms that make you up. Most of your mass does not originate from the Higgs Field. Veritasium made a video about this.
I think that's formulated not very clearly and it may give rise to misunderstandings. What do you consider as the "invariant mass of the material object and a photon" other than the total energy in the center-of-mass frame (devided by ##c^2##), i.e., ##\sqrt{s}/c^2##, where ##s## is the Mandelstam variable. This COM energy is of course conserved in the absorption process. So what you call "conservation of invariant mass" is in fact nothing else than the conservation of energy.
In contradistinction to Newtonian physics there's no additional mass conservation law in relativistic physics. This is due to the different structure of the Poincare group in comparison to the Galileo group. While the Galileo group's Lie algebra has non-trivial central extensions, and only these non-trivial central extensions lead to a useful physical dynamics in non-relativistic quantum theory, mass is conserved non-relativistic quantum mechanics due to a superselection rule. The Poincare Lie algebra has no non-trivial central extensions and thus there's no mass superselection rule, and from the space-time symmetries you thus have only the 10 conserved quantities from the Noether theorem (energy, momentum, angular momentum, center-of-energy velocity from symmetry under temporal translations, spatial translations, rotations, and Lorentz boosts, respectively as the corresponding one-parameter subgroups).
FAQ: Exploring Energy-Mass Equivalence: Converting Energy to Matter in Everyday Life?
What is energy-mass equivalence?
Energy-mass equivalence is a concept in physics that states that energy and mass are interchangeable and can be converted into one another. This is described by Albert Einstein's famous equation, E=mc^2, where E represents energy, m represents mass, and c represents the speed of light.
How is energy converted into matter in everyday life?
In everyday life, energy is converted into matter through nuclear reactions. This can happen in the sun, where hydrogen atoms fuse together to form helium, releasing a large amount of energy in the process. Nuclear power plants also use this process to generate electricity.
Can matter be converted back into energy?
Yes, matter can be converted back into energy through the process of nuclear fission, where the nucleus of an atom is split into smaller parts, releasing a large amount of energy. This is how nuclear weapons and nuclear power plants generate energy.
How does energy-mass equivalence impact our understanding of the universe?
The concept of energy-mass equivalence is crucial in understanding the fundamental workings of the universe. It helps explain how stars and galaxies are formed and how energy is released in the form of light and heat. It also plays a role in the development of technologies such as nuclear power and nuclear weapons.
Are there any practical applications of energy-mass equivalence?
Yes, there are many practical applications of energy-mass equivalence. One of the most well-known is the development of nuclear energy, which is a major source of electricity in many countries. It also has applications in medical imaging and cancer treatment through the use of radioactive isotopes.
