Energy needed to stop the Earth's inner core ---and its effects?
In summary: This means that if we wanted to stop the inner core rotation relative to the mantle, we would need an energy input of 720 terajoules, or about 2.5 x 10 to the 18th power. This is obviously not possible. If someone wants to calculate how much energy would be needed to stop the inner core rotation relative to the mantle, they should consider the following:-The inner core rotation rate, relative to the crust, is of the order of 0.5 degree per year. -The period of rotation is; T ≈ 720 years. -The amount of energy needed to stop the rotation would be in the range of 2.5 x 10 to the
xpell
140
This is not for any kind of homework ---the last time that I went to school was 30+ years ago. However, I am a curious person, I've been asked by other people who know that I love science and I need to calculate this:
As you will most possibly know, a misreading of this paper by the media caused kind of a "panic" about how the Earth's inner core had stopped or even reversed its rotation and its "apocalyptic" effects, etc. When asked, I immediately knew that it wasn't possible ---by energetic reasons, to start with. I more-or-less thought that stopping the core relative to the mantle would need immense amounts of energy "appeared out of the blue" whose application would be truly apocalyptic ---basically, destroying the Earth. Which was and is obviously impossible.
Well, now I've been challenged to "prove it" by the usual you-know-whos and I'd like to calculate how much energy would be actually needed to stop the inner core rotation relative to the mantle, and its effects on the Earth. However, as I said, last time I went to school was 30+ years ago... and that was high school. I initially thought that a simple calculation of the rotational kinetic energy needed to deccelerate the inner core to 0 would be enough, but I'm now realizing that it's possibly more complex than that ---and I'd still wouldn't know how to translate the results into "Earth destruction units".
So... please, is anybody here kind enough to help me?
The Earth's surface crust rotates relative to the stars, once each sidereal day, which is about 23 hours 56 minutes and 4 seconds. Everything inside the Earth rotates at very close to the Earth's crust rotation rate.
Because the Earth's outer core is liquid, the solid inner core can rotate very slightly faster or slower than the crust. That can be measured by changes in the phase of earthquake waves that travel through the inner core, both ways around the Earth.
To calculate the energy needed to stop that relative rotation, we need to know how much faster or slower the inner core is now rotating relative to the crust. If the relative rate has changed recently, then the relative rate will now be very low.
Work out the angular kinetic energy of the inner core rotation, using the moment of inertia of a solid sphere, assuming it was rotating exactly once each sidereal day. Then work out the actual energy of the inner core at the rate it is now rotating. The difference between those, is the energy needed to slow down, or to speed up, the inner core to the same rate as the Earth's crust.
Likes vanhees71, PeroK and topsquark
This seems to be a misconception. Reducing the difference in rotation speed between inner core and mantle can release energy. The total kinetic energy of those two can be lowered by syncing their rotation. This released energy can go into heat or kinetic energy of the liquid outer core.
Likes vanhees71
The trouble lies with this phrase.
inner-core rotation has recently paused
If it had really gone to zero relative to the Sun that would indeed be cataclysmic. But it's clear that they mean that the core and mantle have in the past decade been rotating at the same angular velocity. Usually there is some small difference. In the past decade, not.
You can get the average density of the core, the average radius of the core, and estimate the angular momentum. Then translate that into trillions of Megatons or something like that. But I would guess that nevertheless your friends will keep on believing whatever they feel like believing, which will be whatever most of their friends believe. If you persist in deviation maybe they will no longer consider you a friend. So in situations like this I usually nod sagely and keep my mouth shut.
Likes vanhees71
This might be the misconception of the people "panicking" about it. But @xpell seems to have the misconception that stopping the relative rotation between inner core and mantle would require external energy input.
Likes vanhees71 and Hornbein
Any differential velocity represents a potential source of energy.
Therefore, the period of rotation is; T ≈ 720 years.
Likes vanhees71
FAQ: Energy needed to stop the Earth's inner core ---and its effects?
How much energy is required to stop the Earth's inner core from spinning?
Stopping the Earth's inner core would require an immense amount of energy, far beyond current human capabilities. The inner core is composed primarily of iron and nickel and rotates at a different rate than the Earth's surface. Calculating the exact energy would involve complex physics, including the core's mass, rotational speed, and the forces involved in overcoming its inertia.
What would be the immediate effects on the Earth if the inner core stopped spinning?
If the inner core were to stop spinning, it would disrupt the geodynamo process that generates the Earth's magnetic field. This could lead to a significant weakening or even a collapse of the magnetic field, which protects the Earth from harmful solar and cosmic radiation.
How would a stopped inner core impact the Earth's magnetic field?
The Earth's magnetic field is generated by the movement of molten iron and other metals in the outer core around the solid inner core. If the inner core stopped spinning, this movement would be disrupted, potentially causing the magnetic field to weaken or become unstable, leading to increased exposure to solar radiation and potential damage to electronic systems and power grids.
What geological changes might occur if the inner core stopped spinning?
Geological changes could include increased seismic activity due to changes in the stress and strain within the Earth's mantle and crust. The redistribution of forces within the Earth could lead to more frequent and intense earthquakes and volcanic eruptions.
Could stopping the inner core affect the Earth's climate?
While the direct impact on the climate might not be immediate, the weakening of the magnetic field could have long-term effects. Increased solar radiation could lead to changes in atmospheric chemistry and dynamics, potentially affecting weather patterns and climate. Additionally, disruptions in the Earth's magnetic field could impact the stability of the ozone layer, further influencing climate and weather systems.
