Energy of a charge in between two perpendicular conducting plate .
In summary, the electric force is conservative, so the path doesn't matter. This gives a nice expression for the path integrals when the charges are point particles and zero potential is set at infinity. This can be used to compute both work and potential. So if you compute potential then take the gradient and line integral, you're actually going in a circle.
bs vasanth
1. Two semi infinite conducting plates at right angles to each other, we bring in a charge q from infinity to point (a,b) what is the energy involved in doing so?
coulomb's law and method of images in griffith.
force can be easily calculated by method of images which turns out to:
F=kq^2 [ 1/(2b)^2 - 1/(2a)^2 + 1/((2b)^2+(2a)^2)^0.5]
I can do line integral to this but before that I have to convert them to one single variable, how can i do that ?
I think there's an easier way to do this than doing the line integral. How would you compute this answer if there were no conduction plates, just 4 charges in space (it's the same problem, but I think you're trying too hard because it's a more advanced situation)?
Also, I don't think you've taken into account the directional nature of force in your attempt to solve the problem
Yes later I did take directions for the force and then for the upper right charge I resolved the force on the two axis with an unknown angle theta. Now that i have force as :
F= Kq^2[ (-1/(2x)^2 + cos/(2y)^2+(2x)^2 ) i + ( -1/(2y)^2+sin/(2y)^2+(2x)^2 ) j ]
then I did a line integral as for the first term i need to integrate wrt only x and the second term wrt only y .
Other way was finding the potential for the four charges then find the gradient ( field ) and then use the field to find the work done(energy) . But the potential as cross terms and I find difficult to find the gradient. Kindly suggest me if there is a better way.
The answer is simple and it's against forum rules to give the full answer, so sorry if I'm a bit vague.
The electric force is conservative, so the path doesn't matter. This gives a nice expression for the path integrals when the charges are point particles and zero potential is set at infinity. This can be used to compute both work and potential. So if you compute potential then take the gradient and line integral, you're actually going in a circle.
Once you work out the image charges, this is a high school physics problem. Don't over think it.
Ok I can just use the potentials to calculate the work done by :W=q.V
W = q.k[ -q/2a -q/2b + q/((2a)^2 + (2b)^2 )^0.5 ]
but should I multiply a negative sign to above equation because those were induced charges in moving q and were not present before , therefore there was negative work done.
Related to Energy of a charge in between two perpendicular conducting plate .
What is the energy of a charge between two perpendicular conducting plates?
The energy of a charge between two perpendicular conducting plates is the work required to move the charge from one plate to the other while keeping it perpendicular to the plates.
How is the energy of a charge affected by the distance between the plates?
The energy of a charge is directly proportional to the distance between the plates. As the distance increases, the energy also increases.
What is the role of the electric field in determining the energy of a charge?
The electric field created by the plates is responsible for the energy of the charge. The stronger the electric field, the higher the energy of the charge.
What happens to the energy of a charge if the plates are parallel instead of perpendicular?
If the plates are parallel, there will be no energy of the charge. This is because the charge will not experience any force when moving from one plate to the other.
How is the energy of a charge related to the potential difference between the plates?
The energy of a charge is equal to the product of the charge and the potential difference between the plates. This means that a higher potential difference will result in a higher energy of the charge.
