Energy of a vehicle in a crash
In summary, a fire truck traveling at 58 mph and carrying 62,500 pounds of weight released 3.5 million joules of energy when it crashed. This energy is equivalent to the energy released by about five pounds of TNT exploding.
gilljersey
Hello all, I am in need of some help. I work for a fire department who had a significant fire truck crash last summer. Because of this, my department has set about making a training program for our drivers. Lucky me, I am in charge of said program.
So I need some help.
Here is the story. Last summer one of our Ladder Trucks ( fire truck with the big long ladder on the top of the truck that extends out, not a fire engine that has water) was traveling around 58 mph on a curved road then is lost traction, slide and rolled. No one was seriously hurt.
Here is what we know. Said ladder truck was traveling around 58 MPH and weight 62,500 lbs. I know, using the formula for kinetic energy, ( KE= 1/2 Mass X Velocity squared) that this truck produced 7,016,409.78 ft lbs or 3,508 tons of energy.
What I am looking for is a way so show the members of my department what that much energy looks like. As in, that kind of power in an explosion, or a wrecking ball destroying a building. I need a way to relay to my guys, the power that they are driving down the roads and highways every day.
Luckily when this truck crash, it only hit a telephone pole a picket fence and a few cars. The extent of the damage was very little in comparison to what could have happened.
I have searched the web for a way to show this and have come up with nothing. Someone suggested I try a Science blog, so I leave it up to you. What have you got ?And thanks for the help.
HI there
welcome to PF :smile:
OK for a start, KE isn't measured in tons, its measured in Joules
it would probably be a good idea to convert the imperial mph and lbs to metres/sec and kg's
have a look at the wiki link ...
https://en.wikipedia.org/wiki/Kinetic_energy
There are other wiki entries that compare various blasts with the KE released in Joules
have a little search
cheers
Dave
davenn said:
HI there
cheers
Dave
Thanks for the link. I had looked a a chart and converted everything from jules to pounds (tons) and mph. When dealing with firemen, the simpler the better. We do understand joules, but only in the settings of the defibrillator when used for a CPR. I am trying to keep the explanations as easy for the common person to understand as possible.
You cannot convert from joules to pounds. The one is a unit of energy. The other is a unit of mass.
However, you can convert from foot-pounds to foot-tons. Those are both units of energy. That is the conversion you have actually done. 7 million foot pounds is equal to 3500 foot tons. That is the energy required to lift 3500 tons one foot. Or the energy required to lift one ton 3500 feet into the air.
Or the energy required to lift one 30 ton truck by a little over 100 feet. Which makes sense since rolling down a hill that high would give the truck a speed of 58 mph.
Well, at that mass and velocity, the truck has about 9,529,377 joules of energy, or 9.5 mega-joules. This is equivalent to the energy given off by about five pounds of TNT exploding. So it is, literally, like driving a bomb.
Or, if you prefer, tell them the truck has the same kinetic energy as a motorcycle moving at 500 mph.
Related to Energy of a vehicle in a crash
1. What is the energy of a vehicle in a crash?
The energy of a vehicle in a crash refers to the amount of kinetic energy that is present in the vehicle at the moment of impact. This energy is a result of the vehicle's mass and velocity.
2. How is the energy of a vehicle in a crash calculated?
The energy of a vehicle in a crash can be calculated using the formula E = 1/2 * m * v^2, where E is the energy in joules, m is the mass of the vehicle in kilograms, and v is the velocity of the vehicle in meters per second.
3. What factors affect the energy of a vehicle in a crash?
The energy of a vehicle in a crash is affected by the mass and velocity of the vehicle, as well as external factors such as the type of collision, the angle of impact, and any safety features in the vehicle that may absorb some of the energy.
4. Why is the energy of a vehicle in a crash important?
The energy of a vehicle in a crash is important because it determines the severity of the impact and the potential for injury or damage. Higher levels of energy can result in more serious consequences, making it crucial for car manufacturers to design vehicles that can absorb or redirect this energy to reduce the risk of injury.
5. Can the energy of a vehicle in a crash be reduced?
Yes, the energy of a vehicle in a crash can be reduced through various safety measures such as seat belts, airbags, and crumple zones. These features are designed to absorb or redirect the energy of impact, reducing the force experienced by the passengers inside the vehicle.
  • Mechanical Engineering
  • Other Physics Topics
  • Aerospace Engineering
