Xilus1
- 3
[/B]
The Hamiltonian and wavefunction for the ground state of the hydrogen atom H(1s1) are given,
in atomic units, as ## \hat {H} = - \frac{1}{2} \nabla^2 - \frac {1}{r} ## and ## \phi(1s) = \sqrt {\frac {1}{\pi }} e^{-r} ## . Using the radial portion of the Laplacian in the simplified form ## \nabla^2 = \frac{\mathrm{d^2} }{\mathrm{d} r^2} \frac{\mathrm{d} }{\mathrm{d} r} ## (Basically ignoring the Legendrian)
Verify that the total energy equals -0.5 (Hartree) for H (1s1)
I have a couple of issues here:
The first issue comes from the way question shows the simplified form of the Laplacian (polar coordinates). Looking up the simplified Laplacian (just the radial component) online shows me ## \nabla^2 = \frac {1}{r^2} \frac{\mathrm{d} }{\mathrm{d} r} r^2 \frac{\mathrm{d} }{\mathrm{d} r} ## I don't see how they are the same thing?
Additionally, from my reading, I understand that there should be a centrifugal term in the Hamiltonian here. Usually of the form ## - \frac {l(l+1)}{r^2} ## . I assume its omitted because a s-electron has l=0 ?
My notes/online resources show how to work this problem with centrifugal term included and the common simplified Laplacian, ## \nabla^2 = \frac {1}{r^2} \frac{\mathrm{d} }{\mathrm{d} r} r^2 \frac{\mathrm{d} }{\mathrm{d} r} ##. I know the fist step (once you set up the SE) is to make use of a decaying exponential solution but I'm just unsure of how to get there in the way the question is set up. Any help would be much appreciated.
## \psi(r,\theta,\phi) = R(r)Y(\theta,\Phi) ##
## -\frac{1}{2} \left \{\frac{\mathrm{d^2} }{\mathrm{d} r^2} + \frac {2}{r}\frac{\mathrm{d} }{\mathrm{d} r} - \frac {1}{r} \right \}R(r) = ER(r) ##
## \alpha = -2E ##
## \frac{\mathrm{d^2} }{\mathrm{d} r^2}R(r) + \frac {2}{r}\frac{\mathrm{d} }{\mathrm{d} r}R(r) - \frac {1}{r} R(r) = \alpha R(r) ##
