Energy of photons and the red shift
In summary, the conversation discusses the concept of red shift and how it relates to the behavior of light as a wave or a particle. The speakers compare observations made by an alien on the edge of a galaxy and humans on Earth and conclude that the energy of light is not conserved in different reference frames. The conversation ends with a clarification on energy conservation and a comment on the difficulty of understanding red shift.
davidmroper
Was just learning red shift for my A level final exam and thought about this:
Okay so I have a galaxy with a fixed amount of stars (for the duration of this thought experiment) producing a fixed power of light, which can be assumed to be from its centre. The galaxy is receding from the Earth at a given speed, and we on the Earth observe "red shift".
So, there's a little alien sitting on a planet on the edge of the galaxy, and he watches the light being produced, and records the frequency of light. We sit on Earth in an observatory, and record a "redder" frequency of light. SO, light leaves the galaxy, both observers disagree- which is fine of course, because they aren't observing under the same conditions, and since light is a wave, the observations are fine- the light has been red shifted, what's the problem?
So the Alien guy whips out his pocket gold leaf electroscope, charges up the plate, and shines the light from the centre of his galaxy on the metal plate- the gold leaf falls. The frequency of light from the galaxy is greater than the threshold frequency of the metal. Now we in the observatory, do the same. Our gold leaf doesn't fall- the light is red shifted, so the frequency is lower than the threshold frequency of the metal. Light is behaving as a PARTICLE, and hence, the energy of the particles must have changed spontaneously immediately after passing the alien physicist. So the energy of a photon is lower- in order for the power to remain the same, the number of photons must increase- and the photons must divide.
I assumed my reasoning for the last line there is wrong. So I went online and checked with some sites, and they talked about the idea of energy not being conserved in different reference frames - which doesn't really make sense to me at this moment in time. So any input would be appreciated :) The idea of the energy not being conserved, kind of made me ask where the hell does it go? The cosmic background radiation is red shifted, so would have lost a lot of its energy- where does that go? I was thinking that it might drive the expansion of the universe- you know, increasing its potential energy like a balloon expanding- but I don't really have enough physics knowledge (yet) to do anything more than speculate.
sorry for the long post- I've spent a day pondering when I should've been revising/ learning the course content :P
David.
Space news on Phys.org
davidmroper said:
So, there's a little alien sitting on a planet on the edge of the galaxy, ...
.. when couple of aliens he doesn't like fly past.
So the Alien guy whips out ...
.. a rifle and shoots them. The bullets leave the gun at 1000m/s. The first alien was traveling past at 100m/s and is killed. The second alien passed the shooter at 990m/s and is merely annoyed.
I think you'll find they say the energy isn't the same in the two frames, just as the energy of the bullets, each fired at the same speed relative to the shooter, are not the same in the frames of the targets. In this example energy is conserved as long as you use anyone frame consistently. Conservation in the case of redshift is a harder topic ;-)
Ohhhhhhhhh...! I kinda get it now :) thanks
Related to Energy of photons and the red shift
1. What is the energy of a photon?
The energy of a photon is a fundamental unit of energy that is carried by electromagnetic radiation, such as light. It is directly proportional to the frequency of the radiation, which means that higher frequency photons have higher energy.
2. How is the energy of a photon related to its wavelength?
The energy of a photon is inversely proportional to its wavelength. This means that shorter wavelength photons have higher energy, while longer wavelength photons have lower energy.
3. How does the red shift affect the energy of a photon?
The red shift is a phenomenon where light from distant objects, such as galaxies, appears to have longer wavelengths than it does from closer objects. This means that the energy of the photon is lower than it would be if the object was closer.
4. Can the energy of a photon change?
No, the energy of a photon is constant and does not change as it travels through space. However, it can be absorbed or emitted by particles, which can result in a change in the energy of the particle.
5. How is the energy of a photon calculated?
The energy of a photon can be calculated using the equation E = hf, where E is energy, h is Planck's constant, and f is frequency. Alternatively, it can also be calculated using the equation E = hc/λ, where c is the speed of light and λ is wavelength.
  • Astronomy and Astrophysics
