Energy, once again weird unclear thing
In summary, the car does work against you in the 1m/s frame of reference, but in the 3m/s frame it doesn't because the car is moving.
  • #36
The kinetic energy came from the potential energy of whatever force or device pushed the objects apart.
The point is that the potential energy that was lost by that force or device, regardless of whether it was chemical potential energy in some fuel or elastic potential energy in a spring or electromagnetic potential energy in a field, has decreased by some amount. Neglecting relativistic effects, that amount is the same in all reference frames (e.g. a liter of gasoline has X joules of chemical potential energy). Therefore, for energy to be conserved all reference frames must agree on the overall change in the system's kinetic energy even if they disagree on the work done by each individual force. Thus energy is frame variant, but conserved.
  • #37
I see.
I thought maybe in other frames there is different amount of KE that transform into PE. It still possible energy is conserved is such case, but I'm glad at least this is frame invariant, and correct me if I'm wrong, the amount of transferred energy, from one kind to another.
  • #38
This does indeed happen in relativity (in a way that maintains the conservation of energy and momentum). The math is a little more complicated but, IMO, rather elegant. If you are interested we can discuss that, but I don't want to sidetrack things if you are only interested in non-relativistic effects.
  • #39
Haha, as you see I don't exactly have quick perception.
I'd be glad to learn about modern physics, but now I know nothing about it, and quite far from mastering classic physics.
I do believe things should be learned in order (unlike all this popular science!) as much as this is fascinating.
(But don't worry, I'll learned it someday, and return here to ask weird questions)
I'll just bring again two questions,
(in classic physics of course),
Is the amount of transformed energy, is frame invariant?
I mean, not only KE<->PE but even from one kind of PE to another kind pf PE?
(I almost sure yes, but just a confirmation to close the discussion)
And the other one, do you have then any recommendation for a physics book to learn things deeply?
(how did you all learn?)
  • #40
Non-relativistically, yes. Despite the fact that the work done by any given force is frame-variant.
I learned by working a lot of problems as part of a traditional course. I cannot overemphasize the importance of actually doing some problems, probably more important than a good textbook. My textbook was Serway, which I liked just fine.
  • #41
I was going through the discussion which was very interesting to me.
I was also not clear as to why the work-done as calculated is 2J and 4J in the two cases mentioned in the first post.
Now I think, I have understood .
The basic mistake I was doing was that I was considering the force which accelerates the car is acting only on the car - neglecting that any force has to act between two objects, which results in acceleration of both the objects.
In this case, the force is acting between the ground and the car which accelerates the car in one direction and also accelerates the ground in the opposite direction. Considering the change in KE of both the objects, the work done is same whether observed from the ground or from the reference of the person walking wish some velocity with respect to the ground.
In case of a rocket, the force acts between the rocket and the products exhausted.
Thanks for this thread and the discussions.
  • #42
Fine. Thank you very much for the patient.
Now I still have some more questions about energy, but quite different (one is https://www.physicsforums.com/showthread.php?t=382155&page=3)
Should I open new post for the rest of them, or ask them here?
