Energy per second transferred by the resultant wave
In summary, the energy transferred per second by a progressive waves is directly propotional to the square of its amplitude.
desmond iking
284
the energy transferred per second by a progressive waves is directly propotional to the square of its amplitude, if two waves are in phase and superposed, the energy per second transferred by the resulatant wave propotional to A.) the sum of amplitude. B). The diffrenece of the amplitudes.
my ans is A. since when two waves superposed at a pointy, the resultant displacement is vector sum of individual displacement of two waves. BUT the ans given is B .
So how would you go about proving that you are right?
Maybe a mathematical treatment?
i am not saying i am right. just based on the reason the resultant displacement is vector sum of individual displacement of two waves. i chose A. so am i correct?
Neither A) nor B) seem correct to me. May be I misunderstand the question?
You have said that the model answer says the correct answer is (B) - you did not put that, so you were marked incorrect.
The question only arises if you suspect the model answer is wrong - so you were marked down unfairly.
Therefore, your problem is that you need to find some way to show that the model answer is incorrect, or, failing that, to confirm the model answer is indeed correct.
Your reasoning, how you would go about showing that you are correct, or that they are correct, or whatever, will help us figure out how best to help you.
I'll start you off - you are told that the energy per second of a wave is proportional to the amplitude squared. You write this is as: $$P\propto A^2$$
You are told that two of these waves are in phase - so what is the amplitude of the combined wave?
If the combined wave obeys the same power-amplitude relationship as individual waves, what is the rate of energy transfer for the combined wave?
Please bear in mind that me just telling you if you are correct amounts to telling you the answer - which is against the forum rules.
@Dauto: I could make a case either way - the question seems to be from the UK A-level curriculum referring to mechanical traveling waves. Students will have been expected to use their understanding of the coursework to answer the question - which is why it seems a bit incomplete and glib. Either that or we don't have the full text here.
I want to see OPs reasoning before giving away the answer.
Related to Energy per second transferred by the resultant wave
1. How do you define energy per second transferred by the resultant wave?
The energy per second transferred by the resultant wave is also known as the power of the wave. It is the rate at which energy is transferred by the wave per unit time. This is measured in watts (W) or joules per second (J/s).
2. How is the energy per second transferred by the resultant wave calculated?
The energy per second transferred by the resultant wave is calculated by multiplying the amplitude squared of the wave by its frequency. This can be represented by the formula P = A^2 * f, where P is the power, A is the amplitude, and f is the frequency.
3. What factors affect the energy per second transferred by the resultant wave?
The energy per second transferred by the resultant wave is affected by several factors, including the amplitude, frequency, and medium through which the wave travels. Additionally, the type of wave (e.g. sound, light, electromagnetic) and any interference or absorption in the medium can also impact the energy transfer.
4. Why is understanding energy per second transferred by the resultant wave important?
Understanding the energy per second transferred by the resultant wave is crucial in various fields of science, including physics, engineering, and environmental science. It allows us to quantify and analyze the energy transfer in different systems and make predictions about the behavior of waves.
5. Can the energy per second transferred by the resultant wave be harnessed for practical use?
Yes, the energy per second transferred by the resultant wave can be harnessed and utilized for various practical applications. For example, sound waves can be converted into electrical energy for use in devices such as microphones and speakers. Similarly, light waves can be converted into electrical energy in solar panels for renewable energy production.
