coojoejotaro
- 1
Energy Principle and Nuclear Fission Rhenium HELP! ASAP
For some isotopes of some very heavy nuclei, including nuclei of thorium, uranium, and plutonium, the nucleus will fission (split apart) when it absorbs a slow-moving neutron. Thorium-227, with 90 protons and 137 neutrons, can fission when it absorbs a neutron and becomes Thorium-228. The two fission fragments can be almost any two nuclei whose charges Q1 and Q2 add up to 90e (where e is the charge on a proton, e = 1.6multiply10-19 coulomb), and whose nucleons add up to 228 protons and neutrons (Th-228, formed from Th-227 plus a neutron). One of the possible fission modes involves nearly equal fragments, rhenium nuclei (Rh) each with electric charge Q1 = Q2 = 45e. The rest masses of the two rhenium nuclei add up to less than the rest mass of the original nucleus. (In addition to the two main fission fragments there are typically one or more free neutrons in the final state; in your analysis make the simplifying assumption that there are no free neutrons, just two rhenium nuclei.)
The rest mass of the Th-228 nucleus (formed from Th-227 plus a neutron) is 227.979 u (unified atomic mass units), and the rest mass of each of the two Rh-114 nuclei is 113.894 u, where 1 u = 1.66multiply10-27 kg (approximately the mass of one nucleon). In your calculations, keep at least 6 significant figures, because the calculations involve subtracting large numbers from each other, leaving a small difference. There are three states you should consider in your analysis:
1) The initial state of the Th-228 nucleus, before it fissions.
2) The state just after fission, when the two rhenium nuclei are close together, and momentarily at rest.
3) The state when the rhenium nuclei are very far away from each other, traveling at high speed.
(a) Calculate the final speed v, when the rhenium nuclei have moved very far apart due to their mutual electric repulsion. Keep at least 6 significant figures in your calculations. In your analysis it is all right to use the nonrelativistic formulas, but you then must check that the calculated v is indeed small compared to c. (The large kinetic energies of these rhenium nuclei are eventually dissipated into thermal energy of the surrounding material. In a nuclear reactor this hot material boils water and drives an electric generator.)
(b) Using energy considerations, calculate the distance between centers of the rhenium nuclei just after fission, when they are momentarily at rest. Keep at least 6 significant figures in your calculations.
(c) A proton or neutron has a radius r of roughly 1multiply10-15 m, and a nucleus is a tightly packed collection of nucleons. Therefore the volume of the nucleus, (4/3)piR3, is approximately equal to the volume of one nucleon, (4/3)pir3, times the number N of nucleons in the nucleus: (4/3)piR3 = N(4/3)pir3. So the radius R of a nucleus is about N1/3 times the radius r of one nucleon. More precisely, experiments show that the radius of a nucleus containing N nucleons is (1.3multiply10-15 m)multiplyN1/3. What is the radius of a rhenium nucleus?
(d) You could make a careful scale drawing on paper of the two rhenium nuclei in part (b), just after fission, and label the drawing with the distances that you calculated in parts (b) and (c). If the two rhenium nuclei are nearly touching, this would be consistent with our model of fission, in which the Th-228 nucleus fissions into two pieces that are initially nearly at rest. How big is the gap between the surfaces of the two nuclei? (If you have done the calculations correctly, you will indeed find that the gap is a rather small fraction of the center-to-center distance, which means that our model for the fission process is a pretty good model.)
U = (9e9) (q1q2)/2
K = (1/2)mv^2
I solved for the 3 which is 6.30344986e-15m. I tried to solve for A by setting this equation U = K; (9e9) (q1q2)/2 = (1/2)mv^2; however, I don't know what "r" is?
I need help Thank you
U = (9e9) (q1q2)/2
K = (1/2)mv^2
