Energy production of star given mass?
In summary, calculating the energy production of a star based solely on its mass is not possible due to the complexities of stellar evolution and the various forms of energy production. While some equations and relationships can be used as approximations, they are not accurate for all types of stars. Further research and understanding of stellar dynamics and nucleosynthesis is needed to accurately estimate energy production in stars.
Lagraaaange
82
How would one get the energy production in a star if only given the mass of the star? Something involving mc^2 I suppose?
Astronomy news on Phys.org
There is no direct formula which you can use. The luminosity of a star depends on the rates of its thermonuclear processes, which do depend on the mass of the star. This becomes evident when plotting the temperature vs luminosity of known stars in a Hertzsprung-Russell diagram.
Stars aren't that simple. Brown dwarfs are different from yellow dwarfs are different from blue giants are different from red supergiants.
As stars age, their internal energy producing mechanisms change as different elements are formed internally by the fusion process. Some of this is well understood, some is not so well understood. That's why things like the H-R diagram were developed. Modelling of the internal dynamics of stellar interiors is one area of active research in stellar astrophysics.
This article describes the different forms of energy production in stars:
https://en.wikipedia.org/wiki/Stellar_nucleosynthesis
Some stars support certain types of fusion reactions based on their initial mass. You pretty much have to know the details of these reactions, coupled with knowledge of the evolution of the individual star to estimate how much energy comes out. Knowledge of a star's mass alone is insufficient for this purpose.
Likes QuantumQuest
Bandersnatch said:
He could use the mass-luminosity equations?
Those relations are approximations which apply only to stars on the Main Sequence. They do not cover a variety of other stars falling off the MS.
There are some special mass-luminosity relations for certain stars like white dwarves, but there is no one formula which can be used.
My professor said one can use E=mc^2
You can, but only if you know m, which is the amount of mass being converted to energy by the star at a given instant.
For example, m for the sun is approximately 4.26 million metric tons per second (1 metric ton = 1000 kg) at the present time, but this figure has apparently been lower in the distant past as the sun is thought to have brightened considerably since it was first formed.
BTW, M for the sun is approximately 1.99 × 1030 kg.
https://en.wikipedia.org/wiki/Sun
The relationship between this mass m and the total mass M of a given star is not a direct one.
The density of power production (276.5 watts / m3 ) in the sun's core is surprisingly quite low. It more closely resembles the metabolism of a reptile than an H-bomb detonation.
Energy radiated is entirely different from rest mass, don't just blindly use formulas.
So how would one prepare for an exam question like this?
Beats me. If your professor knows something of which apparently no other astrophysicist is aware, he should publish a paper.
Likes ganguly pranav
What exactly is the question you got asked? "Estimate the energy release of a star with mass X" is not a proper exam question.
"Calculate the energy released by a star that loses x tons/s of mass due to fusion" is a valid question, but completely different from the one you asked in post 1.
Stars with the same mass can have different luminosities. So a function L(m) will fail on this account. Mass-luminosity relationships were certainly investigated a century ago when fusion was not yet understood to be the power source of stars.
Several off topic posts have been removed.
Likes mfb
Related to Energy production of star given mass?
1. How does mass affect the energy production of a star?
Mass is directly related to the energy production of a star. The more massive a star is, the more energy it produces. This is because a higher mass means there is more matter within the star, leading to higher pressure and temperature in the core, allowing for more fusion reactions to occur.
2. What is the main source of energy production in stars?
The main source of energy production in stars is nuclear fusion. This is the process in which hydrogen atoms fuse together to form helium, releasing a large amount of energy in the process. This energy is what powers the star and allows it to emit light and heat.
3. How does the energy production of a star change over its lifetime?
The energy production of a star changes over its lifetime as it goes through different stages. In the beginning, a star's energy production is primarily from hydrogen fusion. As it runs out of hydrogen fuel, it begins to fuse heavier elements like helium and carbon, producing more energy. Eventually, the star will run out of fuel and its energy production will decrease, leading to its death.
4. Can a star's energy production change suddenly?
Yes, a star's energy production can change suddenly due to events like supernovae or other catastrophic events. These events can cause a sudden increase in energy production as a large amount of matter is fused and released, or a sudden decrease if the star is destroyed.
5. What factors besides mass can affect the energy production of a star?
Besides mass, the chemical composition and age of a star can also affect its energy production. A star with a higher percentage of heavier elements will have a higher energy production as these elements can fuse more easily. The age of a star also plays a role, as older stars will have used up more of their fuel and have a lower energy production compared to younger stars.
