holezch
- 251
A 4000 elevator breaks off and falls from rest 12 ft above the surface of a relaxed spring. The elevator has a safety system so that the elevator will always experience a frictional force with a constant magnitude of 1000 lb. The spring constant k is equal to 10 000 lb/ft
a) find velocity just before it hits the spring
b) how much does the elevator compress the spring before it stops?
I solved part a and for 24 ft/s. For part b, I tried using this equation:
sum of conservative forces work + work of friction = change in K
work of gravity + work of spring + work of friction = change in K
then it would be
-ky^2 + (4000 - 1000)y + 1/2mv^2 = 0
because change in K = 0 - K-initial..
plugging in the rest, it should be solvable. But it didn't work out. The reasoning seems fine? what happened? thanks
