Energy radiated from a charge in electric field
In summary, the particle radiated away 16/45 of its initial energy (in terms of radiation) when it was fired head-on at a distant positive charge.
987oscar
This is problem 11.13 from Griffiths Introduction to Electrodynamics 4th Ed.
A positive charge q is fired head-on at a distant positive charge Q (which is held stationary) with a initial velocity [itex]v_0[/itex]. It comes in, decelerates to v=0 and returns out to infinity. What fraction of its initial energy [itex](\frac{1}{2}mv_0^2)[/itex] is radiated away? Assume [itex]v_0<<c[/itex] and that you can safely ignore the effect of radiative losses on the motion of the particle. Answer: [itex]\frac{16}{45}\frac{q}{Q}\left(\frac{v_o}{c}\right)^3[/itex]
Larmor formula
[tex]P=\frac{\mu_0 q^2a^2}{6\pi c}[/tex]
In this problem acceleration depends on x: from Coulomb's law and Newton second Law: [itex]F=\frac{1}{4\pi \epsilon_0}\frac{qQ}{x^2}=m\ddot{x}[/itex]. We don't know the time spent by particle q in its travel in order to compute total energy radiated.
From linear momentum [itex]p=m\dot{x}[/itex], we have [itex]\dot{p}=m\ddot{x}[/itex] and [itex]\dot{p}=\frac{dE}{dx}[/itex].
E is the energy of particle, the sum of kinetic and electrostatic potential energy: [tex]E=\frac{1}{2}m\dot{x}^2+\frac{1}{4\pi \epsilon_0}\frac{qQ}{x}[/tex].
But [itex]\frac{dE}{dx}=\frac{dE}{dt}\frac{dt}{dx}[/itex] and I can write Larmor formula as:
[tex]P=\frac{\mu_0 q^2}{6\pi cm^2}\left(\frac{dE}{dt}\frac{dt}{dx}\right)\left(\frac{dE}{dx}\right)[/tex]
The fraction asked is:
[tex]f=\frac{P}{\frac{dE}{dt}}=\frac{\mu_0 q^3Q}{24\pi^2 \epsilon_0 cm^2x^2\dot{x}}[/tex]
I have differentiate E with respect to x.
I don't know how to evaluate "f" and I don't know if my approach is correct.
Any help? Thanks in advance!
Hello 987oscar. Welcome to PF!
##\small P## is the rate of creation of radiation energy: ##\small P## ## = \frac{dE_{rad}}{dt}##. The energy of the particle, ##\small E##, is assumed to remain essentially constant according to the phrase "you can safely ignore the effect of radiative losses on the motion of the particle".
Note ##\small P## ## = \frac{dE_{rad}}{dt} = \frac{dE_{rad}}{dx} \small \dot{x}##. Use this for the left side of the Larmor formula and try to see where to go from there.
[EDIT: Alternately, you can try the substitution ##\small P## ## = \frac{dE_{rad}}{dt} = \frac{dE_{rad}}{dv} \small \dot{v}##, where ##\small v## is the speed of the particle. I believe this substitution will make life easier!]
Hello TSny:
Yes! as [itex]\ddot{x}=\frac{1}{4\pi\epsilon_0}\frac{qQ}{mx^2}[/itex], I can write Larmor formula as:[tex]\frac{dE_{rad}}{dx}\dot{x}=\frac{\mu_0q^4Q^2}{96\pi^3\epsilon_0^2cm^2x^4}[/tex].
But from Energy Conservation: [tex]\frac{1}{2}mv_0^2=\frac{1}{2}m\dot{x}^2+\frac{1}{4\pi\epsilon_0}\frac{qQ}{x}[/tex], so I find [itex]\dot{x}=\sqrt{V_0^2-\frac{1}{2\pi\epsilon_0 m}\frac{qQ}{x}}[/itex].
Particle goes from infinity to [itex]x_0=\frac{qQ}{2\pi\epsilon_0mv_0^2}[/itex] and returns out to infinity. I have integrated [itex]E_{rad}[/itex] from [itex]x_0[/itex] to infinity and finally I could get the correct answer.
Thank you very much! :smile:
Great! That's the way I did it at first, also. If you want, you can try the other substitution ##\small P ## ##= \frac{dE_{rad}}{dt} = \frac{dE_{rad}}{dv} \dot{v} =\frac{dE_{rad}}{dv} a##. I found the integration easier in this case.
Ok. Iwill try that way too...
Thanks again
FAQ: Energy radiated from a charge in electric field
What is energy radiated from a charge in an electric field?
Energy radiated from a charge in an electric field is the energy that is emitted or transmitted through electromagnetic waves as a result of the movement or acceleration of charged particles. This energy is also known as electromagnetic radiation or electromagnetic energy.
How is energy radiated from a charge in an electric field measured?
The energy radiated from a charge in an electric field is typically measured in units of joules (J) or electron volts (eV). It can also be measured using instruments such as a spectrophotometer or radiometer.
What factors affect the amount of energy radiated from a charge in an electric field?
The amount of energy radiated from a charge in an electric field is affected by factors such as the strength of the electric field, the charge of the particle, and the distance between the particle and the observer. The particle's acceleration also plays a role in the amount of energy radiated.
What is the relationship between energy radiated from a charge in an electric field and its frequency?
The frequency of the electromagnetic waves emitted by a charge in an electric field is directly proportional to the amount of energy radiated. This means that as the frequency increases, so does the energy radiated.
How is energy radiated from a charge in an electric field used in practical applications?
Energy radiated from a charge in an electric field has numerous practical applications, including in communication technology, medical imaging, and power generation. It is also used in research and development in fields such as astronomy, chemistry, and physics.
