Energy released from annihilation
In summary: However, in a nutshell, two particles annihilate and their associated energy and momentum are converted into photons (light particles), which go off in opposite directions at the speed of light.
Einstein's Cat
182
Hypothetically, say there were two bodies, both with a mass of 1kg, and these bodies were to anhilliate as one body was an anti-version of the other body then would the energy released equal the speed of light (due to E= mc squared; the bodies are stationary) or twice the speed of light? In other words, is the energy released from anhilliation the sum of the energy of each particle that anhilliates?
The energy released is determined by the amount of mass that is converted, regardless of objects. If 2kg of mass is converted to energy, then ... well ... 2 kg of mass is converted to energy. It doesn't matter what flavor of mass.
Note, BTW, that there are many ways that things can be converted into energy without it having to be a particle-anti-particle collision. eg, when fusion occurs, two hydrogen atoms combine to form one helium atom, and there is a little bit of mass left over. That little bit of the mass exits the reaction as energy.
BTW, don't forget that squared in there. The amount of energy released from total annihilation of 2kg of mass is 2*c2.
Cheers from your help
When a particle and anti-particle annihilate and photons result, the photons are often paired, going at the speed of light in opposite directions.
In fact, you cannot annihilate two particles to just one photon, because you must obey energy-momentum conservation and the on-shell conditions, i.e., energy and momentum are related by the mass of the particles. The most simple tree-level diagrams for, say, electron-positron annihilation is ##e^+ + e^- \rightarrow \gamma + \gamma##. It's a good exercise to work out the corresponding kinematics of this 2->2 process in some detail, using the Mandelstam variables.
FAQ: Energy released from annihilation
What is energy released from annihilation?
Energy released from annihilation is the energy that is produced when matter and antimatter particles collide and are completely destroyed, converting their mass into energy according to Einstein's famous equation, E=mc^2. This process is also known as pair annihilation.
How much energy is released from annihilation?
The amount of energy released from annihilation is equal to the total mass of the matter and antimatter particles multiplied by the speed of light squared, according to Einstein's equation, E=mc^2. This means that a very small amount of matter and antimatter can produce a large amount of energy.
What is the significance of energy released from annihilation?
The significance of energy released from annihilation is that it demonstrates the conversion of matter into energy, which has important implications in the fields of nuclear physics and energy production. It also helps to explain the balance between matter and antimatter in our universe.
How is energy released from annihilation used in practical applications?
Energy released from annihilation is currently not used in practical applications due to the high cost and technological challenges of producing and controlling antimatter. However, scientists are researching potential uses in fields such as space propulsion, medical imaging, and cancer treatment.
Can energy released from annihilation be harnessed as a source of clean energy?
Currently, energy released from annihilation is not a viable source of clean energy due to the high cost and technological challenges involved in producing and controlling antimatter. However, continued research and advancements in technology may one day make it a viable option for clean energy production.
