Energy released in particle decay w/ relativity
Yes this is the correct value. In summary, the neutral kaon can decay into two neutral pions, with rest energies of 498 MeV and 135 MeV, respectively. The energy released in the decay is 228 MeV, and the momentum of the two neutral pions is 209 MeV/c, traveling in opposite directions. This is determined using the equation E^2 = (pc)^2 + (mc^2)^2 and considering the conservation of energy and momentum.
kpou
25
One of the possible decay modes of the neutral kaon is K-> pion + pion The rest energies of the K0 and pion are 498 MeV and 135 MeV, respectively. The kaon is initially at rest when it decays.
a) How much energy is released in the decay?
b) What are the momentum and relative direction of the two neutral pions
Possible equations:
E0=mc^2
E=(gamma)mc^2
p=(gamma)mv
I got logged out of my last attempt at a post, so let me see if I can replicate it ;x
I figured at first that the energy released would deal with the loss of energy from the 498 MeV = 135MeV+135MeV +?, but these are all rest energies. I'm not sure if there is a difference, but if the energy released by this was not 228 (498-170) MeV then I would have to delve into the wonderful world of relativity. However, I am not sure of what options I have here. Multiplying it by gamma seems too easy. :/
For momentum we take p=mv(gamma). We need to find gamma and v. E0=mc^2 gives us the mass (m=E0/c^2). E=(gamma)mc^2 throws us another nice equation using these variables. We can plop E0=mc^2 in there to target the gamma. We then get E=(gamma)E0. or (gamma)=E/E0. But now we need to find E also.
Any help would be appreciated
First to energy conservation:
E_initial = E_final
Gives you
[tex]m_Kc^2= \gamma m_\pi c^2 + \gamma m_\pi c^2 [/tex]
"Energy released" is the mass difference, i.e. the total amount of kinetic energy. That is a bit tricky, since it is not a fundamental quantity. In reality, energy is not released, it is conserved.. E = rest_mass + kinetic_energy
From the equation above, the E_final = E_initial, you solve for \gamma
Using that the kaon is at rest, the momenta of pion must be back to back, i.e
E_pi 1 = E_pi 2
Use also E^2 = (pc)^2 - m^2c^4
Now make sure you understand these hints, and show us what you obtain and how you do it.
It's true that Ei=Ef but there should be energy released in the form of heat, sound etc and I believe that is what I should be looking for. The Epi+Epi would equal the Ekaon? Working with this in mind I started working on finding gamma
Ei=Ef
mkc^2=2*(gamma)mpic^2
Ek=mkc^2
mk=Ek/c^2=498MeV/c^2
Epi=mpic^2
mpi=Epi/c^2=135MeV/c^2
so: (498MeV/c^2)*c^2=2*(gamma)(135MeV/c^2)*c^2 = 498MeV=370*(gamma)
(gamma)=1.844
mk=2mpi*1.844
So the difference in mass between the two is by a factor of 1.844
define: KE=((gamma)-1)mc^2
KE=.844*(2mpi*c^2)
KE=227.998MeV/c^2
We have
E0=498
KE=228
I would figure I could use E=E0+KE for this, but that doesn't seem to apply. Am I on the right tracK?
energy is "released" in form of kinetic energy of the pions.
But the energy of the pion is not:
Epi=mpic^2, totally unnecessary to even write this line and mpi=Epi/c^2=135MeV/c^2 !
gamma = 1.8444, yes, that is correct answer
The kinetic energy can more easily be evaluated from m_k = 2m_pi + KE = E_final ... but yes, 228MeV is correct, you should not have 227.998MeV/c^2, which is wrong units!
Since you had E_K = 498MeV = 2E_pi, you can evaluate what E_pi is, and you have the relation:
[tex]E^2 = (pc)^2 + (mc^2)^2 [/tex]
which I gave as hint in the last post, why not try to use it?!
E=KE+E0
E=228+498
E=726
726^2=p^2c^2+498^2
279072=p^2c^2
3.1*10^-12=p^2
p=1.76*10^-6
I took E to be the kinetic energy released plus the original value of the kaon at rest. Logically I don't quite understand that though since the KE is energy that was taken from the E0.
I don't think you know how to use the equation...
The energy-momentum-mass relation for a particle, with rest mass m is:
where p is the particle momentum and E is the energy. I thogut that was clear, but it wasn't ...
Now you wanted to find the momentum of the pion, go ahead and try again. Use that the energy of the pion must the (1/2) of the Kaons rest-mass energy.
Of course you cannot logically understand what you did since what you did is rubbish/nonsense.
Yes the downside of missing sleep ; ; I was mixed up on the rest energy there.
E0=135=mc^2
KE=114
E=249
Those are the real values now lol
E^2=p^2c^2+(mc^2)^2
249^2=p^2c^2+135^2
249^2-135^2=(pc)^2
43776=(pc)^2
p^2=43776/c^2
sqrt everything
p=209MeV/c
Thank you for all your patience and help it's been much appreciated :D
Ok, great well done
Related to Energy released in particle decay w/ relativity
1. What is the concept of energy released in particle decay with relativity?
The concept of energy released in particle decay with relativity is based on the theory of relativity, which states that energy and mass are equivalent and can be converted into one another. In the process of particle decay, a large amount of energy is released due to the conversion of mass.
2. How is the energy released calculated in particle decay with relativity?
The energy released in particle decay with relativity is calculated using the famous equation E=mc², where E stands for energy, m for mass, and c for the speed of light. This equation shows the direct relationship between energy and mass, and the amount of energy released can be calculated by knowing the mass of the decaying particle.
3. Can the energy released in particle decay with relativity be measured?
Yes, the energy released in particle decay with relativity can be measured through various experimental techniques. Scientists use particle accelerators to study the decay of particles and measure the amount of energy released during the process.
4. How does the theory of relativity explain the energy released in particle decay?
The theory of relativity explains the energy released in particle decay by stating that the mass of a particle is actually a form of energy. When a particle decays, this energy is released in the form of radiation or other particles, following the principle of conservation of energy.
5. Is the energy released in particle decay with relativity significant?
Yes, the energy released in particle decay with relativity is significant as it is a fundamental process in the universe. This energy is responsible for various natural phenomena, such as radioactive decay, nuclear reactions, and even the energy produced by stars. It also plays a crucial role in modern technologies, such as nuclear power and medical imaging.
