Energy required for creation of photoelectron
In summary, the conversation discusses the energy required for the creation of a photoelectron in silicon, which is 1.14eV. This means that only photons with energy higher than 1.14eV can create a free electron. However, when the energy is higher (above 3.65eV), two electrons are created. This is because the first electron has enough energy to induce the creation of another electron. The difference between these phenomena lies in the fact that the creation of a photoelectron involves removing an electron from the conduction band, while the creation of an electron-hole pair involves moving an electron from the valence band to the conduction band.
paweld
255
I found in one book that the energy required for creation of one photoelectron in silicon
is 1.14eV (that's the energy gap between vallence and conduction band). So only photons
with energy higher than 1.14eV can create one free electron. It's understandable for me.
But when the energy is higher (above 3.65 eV - energy required to create electron-hole pair)
two electrns are created. One can explain this in the following way: photons contributes to creation of only one electron (and of course because of it ceases to exist) but this electon
has enough energy to induce another electron.
But why a photon needs only 1.14eV to create and electron when electron needs as much as 3.65 (In order to move an electron from vallence band to conduction band one always needs the same amount of energy?). What the difference between these phenomena?
well, for the distinction between creation of a photoelectron and a electron-hole pair is that when photon is imparted on an electron and its removing electron out of silicon, it was an electron which was in conduction band earlier... while for the creation of ele-hole pair is done by moving electron from valance band to conduction band.
Related to Energy required for creation of photoelectron
1. What is the definition of "energy required for creation of photoelectron"?
The energy required for creation of photoelectron refers to the minimum amount of energy needed to remove an electron from an atom or molecule, resulting in the formation of a photoelectron.
2. How is the energy required for creation of photoelectron calculated?
The energy required for creation of photoelectron can be calculated using the equation E = hv, where E is the energy, h is Planck's constant, and v is the frequency of the incident light.
3. What factors affect the energy required for creation of photoelectron?
The energy required for creation of photoelectron is affected by the frequency of the incident light, the properties of the material being studied (such as its electron binding energy), and the intensity of the incident light.
4. Why is the energy required for creation of photoelectron important?
The energy required for creation of photoelectron is important because it helps scientists understand the properties and behavior of atoms and molecules. It is also used in various scientific techniques, such as photoelectron spectroscopy, to study materials and their electronic structures.
5. How does the energy required for creation of photoelectron relate to the photoelectric effect?
The photoelectric effect is the phenomena where electrons are emitted from a material when exposed to light of a certain frequency. The energy required for creation of photoelectron is directly related to this effect, as it is the minimum energy needed for an electron to be removed from the material and produce a photoelectron.
