Energy required to lift a heavy box (pulley problem)
In summary, the conversation discusses using an ideal pulley to lift a heavy box and the forces and work involved. The pulley reduces the required force by sharing the weight of the box between two tension forces. However, the work done is not reduced because the displacement over which the force is applied is doubled. This is due to the fact that a pulley only changes the direction of a force, but does not change the amount of work done.
Linus Pauling
190
As you are trying to move a heavy box of mass m, you realize that it is too heavy for you to lift by yourself. There is no one around to help, so you attach an ideal pulley to the box and a massless rope to the ceiling, which you wrap around the pulley. You pull up on the rope to lift the box.
Use g for the magnitude of the acceleration due to gravity and neglect friction forces.
What is the magnitude F of the upward force you must apply to the rope to start raising the box with constant velocity?
Express the magnitude of the force in terms of m, the mass of the box.
2. F = ma
3. I have never done an ideal pulley problem before, so I think if someone just gets me started with a general strategy I'll be able to figure it out. Obviously there's a tension force T pointing upward, opposing the gravity force mg. Is there anything else I need to consider with an ideal pulley that I wouldn't normally? I know that if you're pulling up with constant velocity, then acceleration is zero... but then force is zero. Doesn't make sense to me.
Hello Linus Pauling,
That's right!
Not really. EDIT: All a pulley really does is change the direction of a force. You can check your intuition about the forces acting on the box by drawing a free body diagram for it and making sure that you haven't missed anything. It helps you to be methodical and is a consistent method for solving these problems.
The box will not accelerate unless if there is a NET force acting on it. The net force is the "F" in Newton's second law. If it is moving at a constant velocity, then this means that all of the forces acting on it balance each other out, so that there is no net force in any direction. It does not mean that the applied (pulling) force is zero.
So, there is a tension force of equal magnitude and opposite to the gravity force.
Fnet = T-mg
T=mg
This is incorrect. It says the pulley reduces the force required to life the box, and my answer should be in terms of the mass only. I do not understand.
EDIT: Does the pulley have two tension forces? So it should be 2T=mg ---> T=0.5mg?
Yep, I got it. nevermind.
New question:
Consider lifting a box of mass m to a height h using two different methods: lifting the box directly or lifting the box using a pulley (as in the previous part).
What is {W_{\rm d}}/{W_{\rm p}}, the ratio of the work done lifting the box directly to the work done lifting the box with a pulley?W_d = mg*h
W_p = 0.5mg*h
W_d/W_p = mgh/0.5mgh = 2
This is incorrect. Why?
Where do you get the factor of 0.5 from?
In general, using a pulley system doesn't change the amount of work done.
the 0.5 is because there are two upward tension forces. Could explain (conceptually) why having more upward tension force does not change the amount of work done? Is it simply because of the fact that work depends on displacement, and either way the displacement is the same?
The weight of the box is shared amongst two upward tension forces, so you're only pulling with a force equal to half the weight of the box.
So, why isn't the work done using the pulley system equal to half as much? Because the distance over which the force is applied is equal to the length of rope pulled, which is always twice the height gained by the box. Wikipedia seems to have a good explanation with useful diagrams:
http://en.wikipedia.org/wiki/Pulley
especially in section 2.2, "How it Works." Quoting from the article:
"It is important to notice that a system of pulleys does not change the amount of work done. The work is given by the force times the distance moved. The pulley simply allows trading force for distance: you pull with less force, but over a longer distance."
EDIT: By the way, what I said in my first response about a pulley only changing the direction of a force was incorrect. I was thinking of a fixed pulley, which doesn't provide any mechanical advantage. The problem is talking about a moveable pulley, which in this case provides a mechanical advantage of 2.
FAQ: Energy required to lift a heavy box (pulley problem)
What is the definition of "Energy"?
Energy is the ability to do work or cause change. It comes in many forms, such as mechanical, chemical, thermal, and electrical energy.
How is the energy required to lift a heavy box calculated?
The energy required to lift a heavy box is calculated using the equation E=mgh, where E is the energy in Joules, m is the mass of the box in kilograms, g is the acceleration due to gravity (9.8 m/s²), and h is the height the box is lifted in meters.
Why is a pulley used to lift a heavy box?
Pulleys are used to lift heavy objects because they reduce the amount of force required to lift the object. They distribute the weight of the object over multiple ropes, making it easier to lift.
Does the height of the pulley affect the amount of energy required to lift the box?
Yes, the height of the pulley does affect the amount of energy required to lift the box. The higher the pulley, the more potential energy the box will have, and thus, the more energy will be required to lift it.
How does friction affect the energy required to lift a heavy box using a pulley?
Friction can decrease the amount of energy required to lift a heavy box using a pulley. This is because friction converts some of the potential energy of the box into other forms of energy, such as heat. However, if there is too much friction, it can make the lifting process more difficult and require more energy.
18K
