kyphysics
- 676
- 437
In the old days, you could load your washer drum up with clothes to near the top. Then, when you hit "large/heavy" load, the water would cover your clothes and get up to the top.
Nowadays, machines are designed to be energy efficient/high efficiency and supposedly don't need to use that much water and a "large/heavy" load only fills the water up to the half-way mark of the drum (AT MOST) or, in my uncle's house's case, about 25% of the drum height. I've stood and watched the machine try to clean the clothes (he has a clear see-through lid) and the water level never covered the clothing (about a mix of 10-12 garments of shirts/pants) and things came out soapy and not washed properly at the end.
It's so bad that you either have to wash 5 garments of clothing (MAXIMUM) at a time or add more water yourself after the machine fills up. But, adding more water seems to strain the suspension/shocks (is that the right term?) and have them get "loosened" over time so that now your machine will shake, rattle, and "walk" (literally move inches or even feet out of place when shaking on something like a spin cycle).
This can damage your floor boards and other things (if they "walk" too far, might even the hoses be detached?).
Instead of being energy saving, they are time wasting and even energy WASTING (having to do so many more loads).
These modern washers suck and are designed horribly.
