spaghettibretty
- 6
The wavelength of the radiation emitted when the outermost electron of Al (Aluminum) falls from the 4s state to the ground state is about 395 nm. Calculate the energy separation (in joules) between these two states in the Al atom. Draw an energy level diagram of the states and transitions discussed.
The ground state electron configuration of Al is 1s22s22p63s23p1, if that helps.
In my attempted solution I also use E = h * c / λ.
Rydberg equation: E = -(2.18e-18 J) * (Z)2 * (1/n22 - 1/n12)
[/B]
I'm not one hundred percent sure on what the question is asking. Would the outermost electron falling to the ground state mean it goes from 4s to 3p? In this case do I have to use the rydberg equation with the 2 n's being 3 and 4?
Or does that not matter and all I have to do is plug it into E = h * c / λ, where E is the energy separation between the 4s state and the ground state? I'm also suppose to draw an energy level-diagram, I know how to set it up and all that, but would the arrow go from 4s to 3p or would it go from 4s to the very bottom (the ground state)?
