Energy stored in superconducting magnet
In summary, Tomislav is seeking guidance on how to calculate the total energy dissipated on a discharge heater during the discharge process of a 3 Tesla superconducting magnet that has been in use for 20 years. He suggests plotting a graph of power against time to determine the area under the curve as a possible solution.
JosipMiller
Hello
8 months ago we discharged a 3 Tesla superconducting magnet which is part of old FT-ICR mass spectrometer. Magnet was charged some 20 years ago and working since (which is exceptionally long since it worked in persistive mode, which means no charging in all this time).
During discharge we measure discharge current in 20 time points and of course voltage on discharge heater in the same time. Discharge started at 56.7 Amperes and 1V on discharging heater and normally ended at 0V and 0A.
Now, since discharge process current and voltage were decreasing during process it is easy to calculate power dissipated on the heater during discharge in specific point of time, but how to calculate total energy (Joules) dissipated on discharge heater thrugh time of discharging ?
Thank you,
Tomislav
My first approach would be to plot power against time if possible.
Energy = power x time so it would be the area under this graph
Thank you !
I can plot a graph considering fact that I have 20 measuring points in time with known current and voltage.
Thanks again,
Tomislav
FAQ: Energy stored in superconducting magnet
What is a superconducting magnet?
A superconducting magnet is a type of magnet that is able to maintain a constant magnetic field without the need for a continuous power source. This is achieved through the use of materials that exhibit superconductivity, allowing for the flow of electrical current with zero resistance.
How is energy stored in a superconducting magnet?
The energy in a superconducting magnet is stored in the form of a persistent current. When an electrical current is passed through the superconducting material, it creates a magnetic field that persists even after the current is removed. This allows for the storage of a large amount of energy in the magnet.
What are the benefits of using a superconducting magnet?
Superconducting magnets have many benefits, including the ability to store large amounts of energy, produce strong and stable magnetic fields, and operate at low temperatures. They are also more energy-efficient and have a longer lifespan compared to traditional magnets.
How is the energy released from a superconducting magnet?
The energy stored in a superconducting magnet can be released by either reducing or completely removing the magnetic field. This can be done by either reducing the electrical current or by using a quenching system, which rapidly dissipates the stored energy in a controlled manner.
What are the applications of superconducting magnets?
Superconducting magnets have a wide range of applications, including in medical imaging devices such as MRI machines, particle accelerators, and magnetic levitation trains. They are also used in research and industrial settings for various purposes such as magnetic separation and energy storage.
