Energy transfer in elastic collision.
In summary, the energy transfer equation in an elastic collision between two bodies of masses m and M can be derived using the energy and momentum conservation relations in the laboratory frame. However, in order to solve for the final velocities, one of the four unknowns must be specified. In cases where the direction of one of the bodies after collision is known, the remaining unknowns can be calculated.
Payel Das
How do I derive the energy transfer equation in an elastic collision of two bodies of masses m and M respectively,using the energy and momentum conservation relations in the laboratory frame?
$$\frac{1}{2} m_1 v_0^2 = \frac 1 2 m_1 v^2 + \frac 1 2 m_2 V^2$$
$$m_1 v \cos(\phi)=m_1 v_0 -m_2 V \cos(\theta)$$
$$m_1 v \sin(\phi)=-m_2 V \sin(\theta)$$
but I could not solve for the final velocities $v$ and $V$ respectively
You cannot expect to solve for the unknown quantities here. There are four unknowns, the two final speeds and the two angles, and only three equations. If it is a head-on collision, then it is just a 1-dimensional problem with two unknowns, the velocities after collision. There are two equations, the conservation equations, and the problem can be solved. In the general case, you have to specify one of the four unknowns. In Nuclear physics problems, such as the collision between an α-particle and a gold nucleus, the direction of the α-particle, after collision, is measured, and the corresponding values of the other three quantities can be calculated.
Related to Energy transfer in elastic collision.
1. How is energy transferred in an elastic collision?
Energy is transferred in an elastic collision through the exchange of kinetic energy between two objects. When two objects collide, their kinetic energy is transferred between them, but the total amount of kinetic energy remains constant. This means that the total energy before and after the collision is the same, but it may be distributed differently between the two objects.
2. What is an elastic collision?
An elastic collision is a type of collision between two objects where the total kinetic energy of the system is conserved. This means that the total energy before the collision is equal to the total energy after the collision. In an elastic collision, there is no loss of kinetic energy due to friction or deformation of the objects involved.
3. What is the difference between an elastic and an inelastic collision?
The main difference between an elastic and an inelastic collision is that in an inelastic collision, the total kinetic energy of the system is not conserved. Some of the kinetic energy is lost due to friction or deformation of the objects involved. In an elastic collision, the total kinetic energy remains constant.
4. How does the mass and velocity of the objects affect energy transfer in an elastic collision?
The mass and velocity of the objects have a direct impact on the amount of energy transferred in an elastic collision. The larger the mass and velocity of an object, the more kinetic energy it has. This means that in a collision, a heavier and faster-moving object will transfer more energy to the other object.
5. Can energy be transferred between objects in a perfectly elastic collision?
Yes, energy can still be transferred between objects in a perfectly elastic collision. While the total kinetic energy of the system remains constant, the energy can be distributed differently between the two objects involved. This means that one object may gain kinetic energy while the other object loses the same amount of energy.
  • Mechanics
  • Mechanics
