Energy vs. entropy plot for a Carnot cycle
In summary, to plot the Carnot cycle, you can use a temperature-entropy graph and plot a horizontal line for the isothermal steps and a vertical line for the adiabatic steps. To deal with steps 1 and 3, which involve changes in entropy, you can use the fact that the change in entropy is proportional to the heat absorbed during an isothermal process. You can also use the fact that the area under the U-S curve must be zero to determine the relative magnitudes of the heat absorbed during these steps. This simplified plot can help visualize the different processes and their effects on the system's energy and entropy.
quasar_4
290
I'm trying to understand how one would plot this.
dS = dQ/T
dU = dQ-dW (W is work done by the system, Q is heat absorbed by system, U is energy)
For a closed cycle, dU = 0.
Carnot Cycle:
1- isothermal expansion at Th
2- adiabatic expansion to Tc (lower temp)
3- isothermal compression at Tc
4- adiabatic compression to Th
So in the perfectly idealized case, no new entropy is created during the Carnot cycle. For steps 1, 3, the change in entropy would be given by dS = (1/T) dQ, which could theoretically be integrated if you knew the amount of work being done by the system at each step. And overall for the whole system dU = 0 means dQ = dW for the entire system.
For steps 2, 4, the fact that they're adiabatic means no heat is transferred and there is thus no change in entropy in these steps.
So I can see that for steps 2, 4, the entropy remains a constant. Because dU = 0, the area under the U-S curve must be zero. But how do I deal (qualitatively) with steps 1,3 without knowing anything else about Q or W in these two steps? I know that for a closed cycle, the area enclosed should equal the work done by the system. Do I somehow use this?
To plot this, you can use a graph with temperature on the x-axis and entropy on the y-axis. For steps 1 and 3, you can plot a horizontal line at the temperature Th, since there is no change in entropy during these steps. For steps 2 and 4, you can plot a vertical line at the temperature Tc, since there is no change in temperature during these steps. This will give you a rectangle on the graph, representing the Carnot cycle.
To qualitatively deal with steps 1 and 3, you can consider the fact that for an isothermal process, the change in entropy is directly proportional to the heat absorbed by the system. So, if you know the heat absorbed during these steps, you can plot a line with a positive slope connecting the horizontal lines for steps 1 and 3. The exact value of the slope will depend on the amount of heat absorbed.
You can also use the fact that for a closed cycle, the area under the U-S curve must be zero. This means that the area of the rectangle on the graph must also be zero, which can help you determine the relative magnitudes of the heat absorbed during steps 1 and 3.
Overall, plotting the Carnot cycle on a temperature-entropy graph can help you visualize the different processes and their effects on the system's energy and entropy. Keep in mind that this is a simplified representation and in reality, there may be other factors at play that can affect the plot.
FAQ: Energy vs. entropy plot for a Carnot cycle
1. What is a Carnot cycle and how does it relate to energy and entropy?
A Carnot cycle is a theoretical thermodynamic cycle that describes the most efficient way to convert heat into work. It consists of two isothermal (constant temperature) processes and two adiabatic (no heat transfer) processes. The energy vs. entropy plot for a Carnot cycle shows the relationship between the changes in energy and entropy during the cycle.
2. How does the energy vs. entropy plot for a Carnot cycle differ from other thermodynamic cycles?
The energy vs. entropy plot for a Carnot cycle is unique because it represents a reversible process, meaning that the system can be returned to its initial state without any energy losses. This is not the case for other thermodynamic cycles, which involve irreversible processes and therefore have different energy vs. entropy plots.
3. What does the shape of the energy vs. entropy plot for a Carnot cycle tell us?
The shape of the energy vs. entropy plot for a Carnot cycle is a rectangle, which indicates that the change in entropy is proportional to the change in energy. This means that as the system gains or loses energy, its entropy also changes in a predictable manner.
4. How does the Carnot cycle demonstrate the second law of thermodynamics?
The second law of thermodynamics states that the total entropy of an isolated system always increases over time. The Carnot cycle demonstrates this law by showing that the entropy of the system increases during the adiabatic processes and remains constant during the isothermal processes, resulting in a net increase in entropy over the entire cycle.
5. Can the energy vs. entropy plot for a Carnot cycle be used to calculate the efficiency of a real-world system?
No, the Carnot cycle is a theoretical model and does not account for real-world factors such as friction, heat loss, and imperfect insulation. Therefore, the efficiency calculated from the energy vs. entropy plot for a Carnot cycle is only an ideal maximum value and cannot be achieved in practice.
