hlaija51
- 2
Hello,
My name is Jason, I am a senior high school student (new at using Physics forums), and am currently looking into alternative fuels, specifically a substitute for the popular leaded aviation fuel in use today, 100LL.
100LL contains lead to prevent engine knocking, (pre-detonation of fuel in the cylinder before the spark plug fires), and can with stand higher compression ratios than normal gasoline. It's auto ignition temperature is around 250 degrees centigrade (523 K). I am trying to calculate the temperature of the gasses in the engine cylinder, assuming the piston is flat, and there is no leakage of gasses around the piston ring, when the piston is at top dead centre (right before the spark plug ignites the air fuel mixture.
Many high compression aircraft engines can reach compression pressures around 15-20:1. As some of the bio and alternative fuels I am looking into have various autoignition temperatures, I would like to calculate the temperatures of the lowest compression to highest. This explains the low specs bellow.
The current engine I am trying to calculate is:
a 235 cubic inch
4 cylinder
5.00:1 compression ratio.
Every time I try to calculate this using the combined gas law or by using P1/T1=P2/T2 my answer is ridiculously high, something in the range of 1300 K.
Could I please have some help, trying to figure out the air/fuel vapour temperature in the engine cylinder during the most compression. And could I please get a formula, and see the steps to solving this problem. please only use metric numbers, and STP data
Thanks
Much appreciated.
Jason![Smile :smile: :smile:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
a 235 cubic inch
4 cylinder
Thanks
Much appreciated.
Jason
