Engine design -- Fusion powered rockets
In summary, this artist's concept is of a very large and advanced fusion powered propulsion device that is unlikely to be feasible in the near future.
Xforce
73
I found this interesting engine design on the internet. It is one of the most powerful and largest machines human have ever designed. It is a fusion powered propulsion device, it uses “heavy fusion technology” which can use any elements lighter than Fe-56 as power source. Is this design feasible?
No, not at this time since we can't even get fusion power to work yet.
Likes Dale
IIRC, nearest we've got to a practicable fusion powered rocket is the BIS Daedalus design, but that approach foundered on the difficulties of pulsed 'laser ignition'. Seems that's as hard to 'break even' as Tokamak, Stellerator etc configurations...
( I'm not current on the Polywell design, but I lost interest when that ran into apparently intractable scaling issues... )
This is another view of that thruster...
What is the source of this image?
You should just put it into the right novel and it'll do miracles.
But in real life, no.
The source of this image is google image. Same thing as this concept graph.
You're asking an Engineering Question here. No amount of Artist's Impressions will constitute evidence of the practicability of anything.
The sort of images that you have supplied are presented in countless sales pitches for countless schemes for doing all sorts of things. They can sometimes convince people to part with their money. . . . . . . . . . .
Likes Ryan_m_b
Please make it a habit to post a link to any images that you post at the PF (or at any online discussion forum). It is generally a copyright violation to post images without attribution. Thank you.
That’s not a technical design, that’s art. It might be good, detailed art but it’s no more feasible than a Star Wars technical manual showing you the insides of an X-wing. It’s completely made up for entertainment.
Likes Nik_2213 and Bystander
Ok, I just want to show the size and the exhaust of that engine. The bluish color suggests that the temperature of the plasma beam is more than 40000 degrees kelvin, something like a blue giant star’s surface. Materials will melt down unless there is a magnetic nozzle, and there is one in design. From the huge size and advanced fusion technology, we know that this thing is impossible in the near future. But once we can construct this type of thruster, it will readily propel the largest starships and given enough numbers ang enough time, propel planets:)
Well, that 'China’s First Hard Sci-fi Film' might look a bit interesting but I don't think you should take the 'hard' part so seriously. It might seem bit like guerilla marketing.
I am not advertising anything, I just want to discuss if the scientific principles of this thing works in reality, that is why it is in the sci-fi area. But I only see people repelling this idea.
Not so much "repelling" or rejecting, just providing a reality check. And from your 2nd post above that I quoted, it seems like you understand that it's a (long) ways off. That's all.
From a 'hard' science fiction approach it is difficult to understand a need for such a large device. If you are moving a large asteroid or space habitat, slow and steady makes sense such as a continuous ion drive. A fusion device as suggested in the art work would likely pollute the environment and cause massive radiation problems during deceleration when the star ship or habitat essentially 'follows' the drive exhaust.
Two drive suggestions from published 'scientific' SF:
1) Fusion drives including Bussard ramjets and gravtity control appear in many Larry Niven novels such as "Protector" and the Ringworld series. Niven describes design, operation and dangers associated with fusion drives in "Protector" including long term maintenance.
2) Glen Cook presents a very economical 'hyper drive' powered by matter (hydrogen) / antimatter annihilation in the combat SF novel "Passage at Arms". Climbers resemble your OP picture but at a reasonable size limit of 9,000 tons. The author imposes strict size limits for climbers because they enter another dimension, analogous to submarines using another dimension than surface vessels. Larger craft utilize fusion drives as does a climber before it is fueled with antimatter. See this synopsis if interested https://matthilliard.wordpress.com/?s=passage+at+arms
Hmmm, not sure about that.
Basically, the "heavy fusion" aspect (and I'm acknowledging that this conversation is off an artists diagram so won't get too fussy about the detail) may not be a practical design feature. We know of two basic types of fusion reactions: those that preserve the number of protons and neutrons, and those that involve a conversion between protons and neutrons. The first type is the focus of our fusion-energy projects (ITER for example) and is commonly referred to as the D-T fusion reaction, while the second starts stars burning and is commonly referred to as the H-H fusion reaction. We focus on the D-T in energy generation because the net energy release from the D-T reaction is forty times greater than the H-H reaction. (Which is not to suggest that H-H is "energy poor." Both reactions liberate a lot of energy, esp. compared to how we normally generate the stuff!)
But the trouble with the "heavy fusion technology" aspect is that not all elements fuse usefully. Wikipedia has a very detailed - and physics heavy - overview of this at https://en.wikipedia.org/wiki/Nuclear_fusion#Important_reactions, but essentially, only a few light elements (hydrogen, helium, and boron just barely) make the grade as practical fusion fuels. So expecting to top up the tanks with oxygen or carbon and fuse it up to power the thrusters, is very unlikely.
Likes Klystron
This isn't too surprising when you think PF is a Scientific Forum. The 'appealing' picture in your OP was not likely to be treated seriously, I'm afraid and it probably overshadowed your question about 'Heavy Fusion'.
Related to Engine design -- Fusion powered rockets
1. How does a fusion powered rocket work?
A fusion powered rocket works by harnessing the energy produced by nuclear fusion reactions to create thrust. This is done by using a fusion reactor to heat and compress a fuel (usually a mixture of hydrogen isotopes) until it reaches the temperature and pressure needed for fusion to occur. The resulting fusion reactions release a tremendous amount of energy, which is then directed out of the rocket nozzle to generate thrust.
2. What are the advantages of using fusion power for rockets?
Fusion powered rockets have several advantages over traditional chemical rockets. They have a much higher specific impulse (a measure of how efficiently a rocket uses its fuel), meaning they can reach higher speeds and travel further with the same amount of fuel. They also produce significantly less waste and pollution, as the only byproduct of fusion reactions is helium. Additionally, fusion power is essentially limitless, making it a more sustainable option for long-term space travel.
3. What are the challenges in designing a fusion powered rocket?
One of the main challenges in designing a fusion powered rocket is achieving and maintaining the extreme temperatures and pressures needed for fusion to occur. This requires advanced materials and engineering techniques to withstand the intense heat and radiation produced by the fusion reaction. Another challenge is finding a way to efficiently convert the energy from fusion reactions into thrust, as well as managing the fuel supply and waste products in space.
4. How close are we to developing fusion powered rockets?
While fusion powered rockets are still in the early stages of development, there has been significant progress in recent years. Several research projects and companies are actively working on developing fusion reactors and propulsion systems for space travel. However, there are still many technical challenges that need to be overcome before fusion powered rockets can become a reality.
5. What potential applications could fusion powered rockets have?
Fusion powered rockets have the potential to revolutionize space travel and exploration. They could significantly reduce travel time for missions to other planets and beyond, making it possible to explore further into our solar system and beyond. Fusion powered rockets could also be used for asteroid mining, satellite launches, and potentially even interstellar travel in the future.
  • Science Fiction and Fantasy Media
  • Nuclear Engineering
9K
  • Aerospace Engineering
  • Mechanics
