Engineering ball sorting project, static electricity
In summary, the student is working on a project involving sorting balls of different materials. He has found that two of the balls are similar, but the two remaining balls are of different materials and he is unsure if his assumption that the path of the acetal balls would be unchanged was realistic.
matthew.mre
Hello all,
I am an engineering student currently undertaking a project at univeristy.
It involves the sorting of 4 different balls of which I have deduced how to sort 2 of them leaving just 2 types of balls to sort...
The remaining two are of identical size, 10mm in radius, and are Nylon 66 (density = 1.1g/cm^2, weight = 4.608g) and Acetal (density = 1.4g/cm^2, weight = 5.864g).
After researching the two, I have found that they are both pretty similar. Nylon 66 has got static properties and Acetal is made from polar molecules...
I was thinking maybe if both balls were passed through a tube lined with a sutable material, the nylon balls would become negatively (statically) charged with the acetal balls remaining neutral (being polar). Then the balls could be made to pass through something which produces charge like a capacitor, therefore the negatively charged nylon balls would be attracted to the positive plate of the capacitor therefore changing their paths. The paths of the acetal balls would be unaffected.
Having no experience with that sort of stuff I was wondering whether or not this theory seems realistic or whether anyone has attempted a similar feat? I'm not sure my assumption that the path of the acetal balls would be unchanged was realistic? and I'm not sure if the capacitor could be made with a gap approx 20mm or whether or not that was too large?
The other options would be to do something involving centripetal force or a counter ballanced see saw.
Many thanks :smile:
Matthew
The simplest solution to this problem would be to utilize their weights. They are of the same size but they differ in weight (even though not by much).
You could perhaps use brush hairs carefully woven and fixed internal to a 11mm radius hole. The idea being that the heavier (Acetal) ball will sink through the brush hairs but the lighter nylon ball will pass over.
I have no idea how your contraption is configured and I don't know how fast these balls are going to be moving, so this idea might not work, since the difference in weight is too small.
Cheers.
Going off weight/density is an ok way to go, you could design a precision linkage that drops for a specific weight or the like. What are the other balls you're sorting made of? Is the idea to sort four seemingly (visually) identical balls by material?
Another method could be to find a liquid (for example Brine or Glycerine, see here) that has a density between the two materials, say around 1.25 g/cm^3. One type of ball would float in the fluid, the other would sink. The trick is getting them out of the fluid once they're in there I guess (if we're talking a production application). If you're doing a proof-of-concept science experiment, all you need is a little tank of the stuff.
If you wanted to do a really cool experiment to sort all four balls, find four fluids with properly-spaced densities which don't mix (or react) and drop them into the tank; the balls will drop to their respective fluid layers based on density, kind of like a galileo thermometer.
FAQ: Engineering ball sorting project, static electricity
What is the purpose of the engineering ball sorting project?
The purpose of the engineering ball sorting project is to use static electricity to sort a group of balls and separate them based on a specific characteristic, such as size or color.
How does static electricity play a role in this project?
Static electricity is created when negative and positive charges build up on the surface of an object. In this project, we use static electricity to attract and repel the balls, which allows us to control their movement and sort them accordingly.
What materials are needed for this project?
The materials needed for this project include a power source, conductive materials such as metal rods or plates, insulating materials such as plastic or rubber, and the balls to be sorted.
What is the process for sorting the balls using static electricity?
The process involves creating a static charge on the conductive materials, which will then attract or repel the balls depending on their charge. By strategically placing the conductive materials, we can control the movement of the balls and sort them into different groups.
What are the real-world applications of this project?
This project has various real-world applications, such as separating recycling materials, sorting grains or seeds by size or weight, or even sorting DNA molecules for genetic research. It can also be used in industrial settings for quality control and sorting of different materials.
