MHB Engineering - Stress and Buckling Load problems
The discussion revolves around a participant seeking assistance with engineering problems related to stress and buckling loads during a summer camp course. They present three specific problems involving buckling loads of different samples, stress calculations for a circular rod, and force requirements for stretching a wire. Respondents emphasize the importance of understanding the underlying formulas, such as those for stress and Hooke's Law, rather than simply providing answers. The participant expresses gratitude for the guidance and acknowledges that they are gaining clarity on the material, despite initial confusion. Overall, the conversation highlights the collaborative effort to reinforce engineering concepts and problem-solving skills.
Plasma2
Hello,
I am in an engineering summer camp, but since this is a condensed course and it seems the professors assumed the class already had some background in the subject, I am slowly getting lost. They gave us practice tests from previous years, and I was wondering if someone could show me how to complete a few problems. Though I know you wonderful people will explain your answers, could you also tell what conversions you use as well since that is likely what we will have to apply ourselves? Thanks in advance!
1)
You have two samples of the same material. These samples have different lengths and diameters.
  • Sample 1: 10 cm long and 1.0 mm diameter -- Buckling load at failure: 10kN
  • Sample 2: 20 cm long and 1.0 mm diameter
What is the buckling load that would cause Sample 2 to fail? (report answer in kN)
2)
A circular rod with a diameter of 10 mm experiences a tensile force of 100 kN. What is the stress in the rod in MPa?
3)
A wire that is 1.0 mm in diameter is stretched from 10.6 cm to 10.9 cm by a force of 150 N. Assuming the elastic limit is not exceeded, what is the force required to stretch the wire from 10.6 cm to 11.1 cm?
Mathematics news on Phys.org
Plasma said:
Hello,
Hi again Plasma! ;)
To be honest, I'd rather not just give fully worked answers.
I believe that's ultimately not very useful to you, and no fun for me either.
Anyway, let's see what we can do.
Plasma said:
1)
Do you have a formula for the stress in a material of a certain length and diameter?
We should be able to tell what the answer is from that formula.
On a different note, do you have a sense of what's going on?
We have a sample that is twice as long. What do you think about its buckling strength when the same load is applied?
Plasma said:
2)
Again we're looking for a formula. Do you have one?
Okay. Let me help you a bit here.
The definition of stress $\sigma$ is:
$$\sigma = \frac F A$$
where $F$ is the tensile force, and $A$ is the area of a cross section.
Does it look familiar? Can you find the stress from that?
Plasma said:
3)
This is where Hooke's Law comes into play. Did you see it in your notes?
Do you have a formula for the force when stretching a wire by a certain amount?
Hooke's Law says that the force is linear with the distance it is stretched - if there is no permanent elastic deformation.
So stretching it twice as far means the force is twice as big.
Can we find the force from that?
Seems fair.
Found it, 1/4 the strength.
I knew that part, I didn't know how to convert between Newtons and Pascals
Not in my notes, but online yes. Thanks for the pointer.
Sorry for the long delay, but thanks for encouraging me to get it. After all said and done, these were not the parts of the quiz I lost points on. If you want I can show you the final result that will come of all these and other calculations once my group and I build our spaghetti bridge. Anyway, off topic. Thanks for the help.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
