- #36
DrChinese
- 1,906
rede96 said:Thanks for your help with this. I think I understand the EPR argument a lot better now and can see how Bell's inequality and experimental results lead to the conclusion that there is something very non-classical going on. But my mind still struggles accepting that this is spooky action at a distance, even though it is obvious one is forced to accept that conclusion.
I was also curious to know is entanglement something that persists? So once the wave function has collapsed then I assume that anything further I do to particle A, such as run it through a magnetic field and change the spin direction for example, would have no effect on partial B? Or are they forever entangled?
The general rule is that once you measure either particle, entanglement ceases.
However, there are multiple degrees of entanglement. It is also possible to collapse one degree and leave others intact. For example, you collapse the spin degree and leave position/momentum entanglement intact for the particle pair.
