Entanglement and general relativity
In summary, the concepts of general relativity seem to fit (sorta) well with quantum physics, but how does the quantum world fit with general relativity? Specifically, I'm wondering if entanglement has any grounds that you can derive from GR?Entanglement is a purely quantum mechanical phenomenon that arises due to the linearity of the Schrodinger equation when applied to states of composite systems in superpositions of states of the subsystems. GR on the other hand is a purely classical field theory so you certainly cannot "derive" entanglement from it.However, standard QM (and even standard QFT) are done on flat backgrounds so GR doesn
ryan albery
67
The concepts of general relativity seem to fit (sorta) well with quantum physics, but how does the quantum world fit with general relativity? Specifically, I'm wondering if entanglement has any grounds that you can derive from GR?
EDIT: Furthermore standard QM (and even standard QFT) are done on flat backgrounds so GR doesn't even come into play.
ryan albery said:
So basically you're saying that GR doesn't make a difference in regards to anything, so long as the geometry is 'flat'?
If the space-time geometry is flat there is no gravity so GR is of no relevance.
I wish I could wrap my brain around that. A flat spacetime means no GR... is that true?
A flat spacetime means you don't need GR and can get by with just SR - although you can use the methods of GR if you wish. Special relativity is "special" because it applies only to the special case of flat zero-curvature spacetime, whereas general relativity works for the general case of any curvature, whether zero or not.
Many GR textbooks start with a general relativistic treatment of flat spacetime, so that the student can get comfortable with the new mathematical machinery in a familiar context.
there is both flat and curved treatments of relativity in QFT, referred to as gauge invariants.
types of gauge invarients are curved (space-time) and flat (tangent space) indices; coordinate (space-time) and local Lorentz (tangent space) symmetries. The flat and curved indices of Yang Mills can be found on page 591 on this QFT article. There are numerous other relativity treatments in this article. Been studying it for some time now, however my progress has been slow. Had to improve several fields of study to get even started on this article. So I am by no where near the level of discussion of it with any accuracy.
"Fields"
http://arxiv.org/pdf/hep-th/9912205v3.pdf
edit: I couldn't find any entanglement treatments in this paper. Was checking for it took some time. 885 pages lol
there is some GR correlations to entanglement to GR in these article, however one is dealing with wormholes lol.
Wormholes and Entanglement
http://arxiv.org/pdf/1401.3416.pdf
Action and entanglement in gravity and field theory
http://arxiv.org/pdf/1310.1839v1.pdf
the fields article might have some detail, could be hidden under a metric I didn't recognize, those are the only articles I could find. Hope they help
edit found some more
http://arxiv.org/pdf/1212.5183v1.pdf
Gravitation and vacuum entanglement entropy
http://arxiv.org/abs/1204.6349
if you run through the supportive references, should lead to numerous articles
FAQ: Entanglement and general relativity
What is entanglement?
Entanglement is a phenomenon in quantum mechanics where two or more particles become connected in such a way that the state of one particle is dependent on the state of the other, regardless of the distance between them.
How does entanglement relate to general relativity?
While entanglement is a concept in quantum mechanics, general relativity is a theory of gravitation. The two theories are not directly related, but some scientists are exploring the possibility of a connection between them through theories such as quantum gravity.
Can entanglement be used for communication?
No, entanglement cannot be used to communicate information. While the state of one particle can affect the state of another, this effect is random and cannot be controlled. Therefore, entanglement cannot be used for faster-than-light communication.
What are the potential applications of entanglement?
Entanglement has the potential to be used for quantum computing, cryptography, and teleportation. It may also have implications for our understanding of the fundamental laws of physics.
Is entanglement a proven phenomenon?
Yes, entanglement has been observed in numerous experiments and is an accepted concept in quantum mechanics. However, there is ongoing research to further understand and utilize this phenomenon.
