Entanglement in delayed choice quantum eraser (DCQE)
In summary: I.E. it is in a state of pure Zeplinian dynamics)? In other words, does the entanglement still exist after the particle has left the device? If so, what is the probability of finding it in each of the possible states it could be in? The entanglement between the photons remains even after the photon has left the device. However, the probability of finding it in each of the possible states it could be in is not certain.
San K
911
In the delayed choice quantum eraser (DCQE), such as the walborn paper, link below:
http://arxiv.org/PS_cache/quant-ph/pdf/0106/0106078v1.pdf"
we try to find out the polarization/path via quarter wave plates (see diagram on page 7 of the paper)
Now does not entanglement break (i.e. wave function collapse) at that point?
later when we erase which-way info, does the same entanglement again re-join?
what is the popular explanation among physicist on this?
Just putting quarter wave plates in does not constitute a measurement as it is a reversible process. As long as no measurement has been performed on one of the photons, entanglement should not be broken.
"The opera ain't over till the fat lady sings" holds for some branches of physics, too.
thanks Cthugha, well put.
when has the measurement, in your opinion, been performed (i.e. the fat lady has finally sang..;)):
1. when the photon has passed through the QWPs
or
2. when one of the (twin pair) photon has struck the screen
or
3. when both the pairs have stuck the screen
or
4. when both the pairs have stuck the screen and have been compared/matched via co-incidence counterI guess it would be 2 above and you mean the same.
if let' say scientists figured a way where the quarter wave plate would flash or something...when the photon passed through
would the measurement then have taken place?
You may think about the experiment that way:
We count only coincidences with detector D_p clicks (that is Anton Zeilinger's answer to the question: what is photon? Photon is just a click in our photon detector!) and we ignore all clicks in D_s which occur when D_p stay silent. As photons in both branches (p and s) are entangled, we are sure that we measure only those photons, which, at the path BBO-QWPs are linearly polarized, perpendicularily to POL1 axis. It doesn't matter if we reject some clicks because the coincidence hadn't taken place, or because the light had been absorbed in the polarizator polarizing the beam s linearily.
Thus our setup is equivalent to pretty classical experiment with light bulb as a source (at BBO) followed on its path by polarizator. You don't need any QM to analyze it - high school wave optics is pretty sufficient to find the results.
If you really want to think about it in terms of Bohr's measurements, wave function collapse, and Bell's mysteries, you should just take that final measurement is the moment when some coincidence logic fills a click into the histogram - (4) of your list. Probably that is the only tricky point about entanglement: you may think about measurement (in Copenhagen meaning) only after the coincidence between both elements of entangled pair is computed.
San K said:
... Now does not entanglement break (i.e. wave function collapse) at that point?
No. You can perform all kinds of manipulations on entangled particles which do NOT collapse the wave function. The reason is that the manipulation is applied similarly against all possible paths. Collapse only occurs when some paths are selected over others, which doesn't happen with a wave plate.
all kinds of manipulations but none that would change/skew the probability of getting a particular spin?
interesting. thanks for the info DrChinese
if we were to look with a telescope: would some paths be selected over others?
if we were to use a polarizer: would some paths be selected over others?
Ok, so I have a question related to this. The way I have always understood this is that, when one of the particles interacts with a device like this (the double slit with QWP's, or a PBS), what happens is that the polarization of that particle becomes entangled with the different spatial paths after the device. You can then choose to detect the particle (thereby obtaining which path information), or you can re-combine the paths (as in an MZ interferometer), to recreate the polarization-entangled state.
My question related to this is, what the correct way to describe the entanglement particle B (assuming it is not interacting with any sort of apparatus), while particle A is spatially entangled with a PBS ( or whatever)? In other words, what is particle B entangled with during this interval? Obviously it must still be entangled with particle A in some fashion, because we can choose a context where the original polarization entangled state is restored. Or is this simply not a meaningful question to ask, without first defining the context of the rest of the experiment?
Related to Entanglement in delayed choice quantum eraser (DCQE)
1. What is entanglement in delayed choice quantum eraser?
Entanglement in delayed choice quantum eraser (DCQE) is a phenomenon in quantum mechanics where two or more particles become connected in a way that their states are dependent on each other, even when separated by vast distances. In DCQE, this entanglement occurs when two particles are created and then separated, but their entangled states are not determined until later on in the experiment.
2. How does delayed choice quantum eraser work?
In delayed choice quantum eraser, a laser is used to create a pair of entangled particles, usually photons. One photon is sent through a series of beam splitters and detectors, while the other is sent to a separate location. The actions of the first photon are then used to determine whether or not the second photon will be measured and which path it will take. This allows for the entanglement to be measured and observed, even after the particles have been separated.
3. What is the significance of delayed choice quantum eraser?
The significance of delayed choice quantum eraser lies in its ability to demonstrate the strange and counterintuitive principles of quantum mechanics, such as entanglement and superposition. It also challenges our understanding of causality and the idea that events can only be influenced by events that occurred before them. DCQE has important implications for quantum information processing and the development of quantum technologies.
4. Can delayed choice quantum eraser be used for practical applications?
While delayed choice quantum eraser has been primarily used for fundamental research in quantum mechanics, it has potential applications in quantum computing and communication. By using the entanglement and superposition of particles, information can be transmitted and processed in a more efficient and secure manner. However, more research and development is needed before DCQE can be applied in practical settings.
5. What are the criticisms of delayed choice quantum eraser?
One of the main criticisms of delayed choice quantum eraser is that it relies on the interpretation of quantum mechanics known as the Copenhagen interpretation, which some scientists argue is incomplete. Additionally, some argue that the results of DCQE experiments can be explained by classical physics and do not necessarily prove the existence of entanglement. Further research and experimentation is needed to fully understand the implications and limitations of delayed choice quantum eraser.
