Entanglement on the Many Worlds model
In summary, the conversation discusses the relationship between entanglement and wave function collapse in the context of the Many Worlds model. It is stated that while entanglement itself does not depend on collapse, the phenomenon of 'spooky action at a distance' does. The MWI is said to describe this phenomenon without the need for collapse, instead using a superposition of states. It is also mentioned that MWI is not considered to have a 'spooky action at a distance', but it is not considered to be local in the traditional sense.
jeremyfiennes
323
TL;DR Summary
Entanglement's non-locality depends on the collapse of the common wave function. The Many Worlds model has no collapse. Does it also have no entanglement?
Entanglement's non-locality ('spooky action at a distance') depends on the instantaneous collapse at all points in space of the entangled particles' common wave function. The Many Worlds model has no wave function collapse. Does it also have no entanglement?
Your premise is wrong: entanglement does not depend on collapse.
If the wave function takes on a certain form, we have entanglement; MWI and collapse both work just fine on that wave function.
Likes PeterDonis
Entanglement itself doesn't depend on collapse. But 'spooky action at a distance' does. That is my query: how does MWI account for this?
The phenomenon that people sometimes (and, in the modern view, inaccurately) describe as “spooky action at a distance” does not depend on collapse.
You can choose to describe it in terms of collapse, but it is not necessary - MWI describes it just fine without collapse. A collapse interpretation says that we start with a superposition of “A up B down” and “A down B up” and the interaction with either measuring device changes the state to either “A up, A measuring device reads up, B down, B measuring device reads down” or “A down, A measuring device reads down, B up, B measuring device reads up”. MWI says that the interaction with either measuring device changes the state to a superposition of those two states, only one of which will be observed.
Likes PeterDonis
Ok. Thanks.
MWI does not have a spooky action at a distance. But it does not mean that MWI is local. MWI is alocal in the sense that, at the fundamental level, local objects (namely objects defined on a spacetime point) don't even exist.
Likes jeremyfiennes
Related to Entanglement on the Many Worlds model
1. What is entanglement on the Many Worlds model?
Entanglement on the Many Worlds model is a phenomenon in quantum mechanics where two or more particles become connected in such a way that the state of one particle is dependent on the state of the other(s). This means that measuring the state of one particle will automatically determine the state of the other(s), regardless of the distance between them.
2. How does entanglement work on the Many Worlds model?
On the Many Worlds model, entanglement occurs when particles interact with each other and become entangled. This means that they share a single quantum state, even if they are separated by large distances. When one particle is measured, the other(s) will also be affected, resulting in a correlation between their states.
3. What is the significance of entanglement on the Many Worlds model?
Entanglement on the Many Worlds model is significant because it allows for the possibility of multiple parallel universes or "worlds". Each time a measurement is made on an entangled particle, the universe splits into multiple branches, each representing a different outcome. This means that there are countless parallel universes existing simultaneously.
4. Can entanglement on the Many Worlds model be observed in real life?
Yes, entanglement on the Many Worlds model has been observed in experiments. One famous example is the EPR (Einstein-Podolsky-Rosen) paradox, where two entangled particles were separated by a large distance and still exhibited correlated behavior when measured. This phenomenon has also been observed in other experiments, providing evidence for the existence of parallel universes.
5. What are the potential applications of entanglement on the Many Worlds model?
Entanglement on the Many Worlds model has potential applications in quantum computing, cryptography, and teleportation. By utilizing the parallel universes, quantum computers could potentially solve complex problems much faster than classical computers. Entanglement also allows for secure communication through quantum key distribution, and the concept of quantum teleportation relies on entangled particles to transfer information instantaneously between two points.
  • Quantum Interpretations and Foundations
9K
