Entanglement Witnesses close to GHZ states
In summary: This observation is crucial for constructing the entanglement witnesses mentioned in the paper for detecting entanglement close to GHZ states. In summary, the paper discusses a method for detecting entanglement close to GHZ states by constructing entanglement witnesses using correlation operators and stabilizer groups. It is observed that if these operators commute locally, the maximum of their expectation values for separable and entangled states coincide. This is important for the construction of the entanglement witnesses.
Danny Boy
49
TL;DR Summary
Theoretical query regarding a statement made in a paper on entanglement detection using entanglement witnesses.
Consider page 2 of Toth's paper Entanglement detection in the stabilizer formalism (2005) . To detect entanglement close to GHZ states, they construct entanglement witnesses of the form $$\mathcal{W} := c_0 I - \tilde{S}_{k}^{(GHZ_N)} - \tilde{S}_{l}^{(GHZ_N)},$$
where ##\tilde{S}_{k/l}^{(GHZ_N)}## are elements of the stabilizer group and $$c_0 := \text{max}_{\rho \in \mathcal{P}}\big( \big\langle \tilde{S}_{k}^{(GHZ_N)} + \tilde{S}_{l}^{(GHZ_N)} \big\rangle_{\rho} \big),$$ where ##\mathcal{P}## denotes the set of product states.
Definition: Two correlation operators of the form ##K = K^{(1)} \otimes K^{(2)} \otimes \cdot \cdot \cdot \otimes K^{(N)}~\text{and}~L = L^{(1)} \otimes L^{(2)} \otimes \cdot \cdot \cdot \otimes L^{(N)}## commute locally if for every ##n \in \{1,...,N\}## it follows ##K^{(n)}L^{(n)} = L^{(n)}K^{(n)}##.
Question: In the paper (page 2), an observation which follows states:
Hence it follows that if ##\tilde{S}_{k}^{(GHZ_N)}## and ##\tilde{S}_{l}^{(GHZ_N)}## commute locally then the maximum of ##\big\langle \tilde{S}_{k}^{(GHZ_N)} + \tilde{S}_{l}^{(GHZ_N)} \big\rangle## for separable and entangled states coincide.
Is it clear why this statement holds true? Thanks for any assistance.
Yes, it is clear why this statement holds true. By definition, if ##\tilde{S}_{k}^{(GHZ_N)}## and ##\tilde{S}_{l}^{(GHZ_N)}## commute locally, then for any state, it can be written as a product of its local states, i.e., $$\rho = \bigotimes_{n=1}^N \rho_n.$$ Since the correlation operators commute, it follows that $$\big\langle \tilde{S}_{k}^{(GHZ_N)} + \tilde{S}_{l}^{(GHZ_N)} \big\rangle_\rho = \prod_{n=1}^N \big\langle \tilde{S}_{k}^{(GHZ_N)} + \tilde{S}_{l}^{(GHZ_N)} \big\rangle_{\rho_n}.$$ Therefore, since the local states are always separable, the maximum of ##\big\langle \tilde{S}_{k}^{(GHZ_N)} + \tilde{S}_{l}^{(GHZ_N)} \big\rangle## for separable and entangled states coincide.
FAQ: Entanglement Witnesses close to GHZ states
What are entanglement witnesses?
Entanglement witnesses are measurements or observables used to detect and quantify the amount of entanglement in a quantum system. They are typically operators that have specific properties, such as being positive and Hermitian, that allow them to distinguish between entangled and separable states.
What are GHZ states?
GHZ states, or Greenberger-Horne-Zeilinger states, are highly entangled quantum states that involve multiple particles. They are named after the physicists who first proposed them and are characterized by all particles being in a superposition of two states at the same time.
How are entanglement witnesses used to detect GHZ states?
Entanglement witnesses can be used to detect GHZ states by measuring certain correlations between the particles in the system. These correlations are only present in entangled states, so if they are observed, it is a strong indication that the system is in a GHZ state.
What is the significance of entanglement witnesses in quantum computing?
Entanglement witnesses play a crucial role in quantum computing as they are used to verify the presence of entanglement in quantum systems. This is important because entanglement is a key resource for many quantum computing algorithms and protocols.
Can entanglement witnesses be used to create GHZ states?
No, entanglement witnesses do not have the ability to create GHZ states. They are only used to detect and quantify the amount of entanglement in a given system. Creating GHZ states requires specific operations and techniques, such as quantum gates and measurements, that can manipulate the quantum state of particles.
