Enthelpy, heat of neutralization, calorimetry
In summary, the conversation discusses the mixing of HCl and Ba(OH)2 solutions in a constant-pressure calorimeter and how to calculate the final temperature of the mixed solution using the heat of neutralization and the equation q=msΔt. The final answer should be 26.3 degrees C.
maxbashi
A quantity of 2.00x10^2 mL of .862 M HCl is mixed with 2.00x10^2 mL of .431 M Ba(OH)2 in a constant-pressure calorimeter of negligible heat capacity. The initial temperature of the HCl and Ba(OH)2 solutions is the same at 20.48 C.
For the process
H+(aq) + OH-(aq) --> H2O (l)
the heat of neutralization is -56.2 kJ/mol. What is the final temperature of the mixed solution?
I'm thinking all I need is q=ms delta t
q=(heat of neutralization per mol)(number of moles H2O)
q= -56.2 kJ/mol x (200 mL*.862mol/1000mL) = -9.69 kJ
If -9.69 = q = ms(T(f)-T(i))
Then T(f) = q/ms + T(i)
= -9690 J/(400g)(4.184g/J*C) + 20.48*C
= 121.8 degrees C
The answer should be 26.3 degrees C. Any help?
Do you know how to use calculator?
[tex]\frac{9690}{400\times4.184} + 20.48[/tex]
and not
[tex]\frac{9690}{400} 4.184 + 20.48[/tex]
(not to mention fact that you have lost minus sign, in a way luckily for you).
well that's embarrassing. thanks.
Happens :devil:
I would first commend you for showing your work and providing the necessary equations and information to solve the problem. Your approach is correct, however, there are a few mistakes in your calculations.
Firstly, the heat of neutralization is given in kJ/mol, so you need to convert it to J/mol by multiplying it by 1000.
Secondly, the number of moles of water formed should be the same for both the HCl and Ba(OH)2 solutions, so you should use the same volume (200 mL) and molarity (0.862 mol/L) for both solutions.
Finally, the specific heat capacity (s) should be for water, not the total mass of the solutions. So the correct value for s should be 4.184 J/g°C.
Correcting these mistakes, we get:
q = (-56.2 kJ/mol x 1000 J/kJ) x (200 mL x 0.862 mol/L) = -97.38 kJ
T(f) = -97.38 kJ / (200 mL x 0.862 mol/L x 4.184 J/g°C) + 20.48°C = 26.3°C
Therefore, the final temperature of the mixed solution is indeed 26.3°C. Great job on attempting the problem and keep up the good work!
Related to Enthelpy, heat of neutralization, calorimetry
What is Enthalpy?
Enthalpy is a measure of the total energy of a thermodynamic system, including both its internal energy and the work required to create or maintain its pressure and volume.
What is the heat of neutralization?
The heat of neutralization is the energy released or absorbed when an acid and a base react to form a salt and water. It is a measure of the strength of the acid and base, and is always accompanied by a change in enthalpy.
How is the heat of neutralization measured?
The heat of neutralization is typically measured using a calorimeter, which is a device that can accurately measure changes in temperature. The acid and base are mixed in the calorimeter and the temperature change is recorded, allowing for the calculation of the heat of neutralization.
What is calorimetry?
Calorimetry is the science of measuring heat and energy changes in chemical reactions or physical processes. It involves the use of a calorimeter to measure the change in temperature and calculate the heat released or absorbed.
What is the relationship between enthalpy and calorimetry?
Enthalpy is directly related to the heat measured in a calorimetry experiment. The change in enthalpy (ΔH) of a reaction is equal to the heat released or absorbed (q) divided by the number of moles of the limiting reactant (n). This relationship is known as the heat of reaction, and it is a key concept in calorimetry.
32K
