pivoxa15
- 2,255
- 1
Why is enthalpy so commonly described only in constant pressure situations? It applies to change in pressure environments as well.
Enthalpy is a thermodynamic property that describes the total energy of a system, including both its internal energy and the work required to create or destroy the system.
Enthalpy includes the energy needed to create or destroy a system, while internal energy only describes the energy contained within the system.
In constant pressure situations, the system is allowed to exchange heat with its surroundings, which can affect the enthalpy of the system. This makes it a useful parameter to consider in these situations.
Yes, enthalpy can be negative if the system releases more energy than it absorbs. This is often seen in exothermic reactions.
Enthalpy is measured in units of energy, such as joules or calories. It can be determined experimentally using calorimetry, or calculated using mathematical equations based on the internal energy and work done on or by the system.
