Enthelpy under uniaxial compression of solid
In summary, the enthalpy under uniaxial compression along z of a solid is given by: H=U+PzV. This appears to make sense as during uniaxial compression the Pz pressure component is the only one doing work (zero transverse strain). However, at the starting point of this second uniaxial compression the enthalpy is then given simultaneously by U+PzV and U+PyV, which can't possibly be true for general non-hydrostatic stress conditions.
g_mogni
48
Hello,
I have found several references (I can send you the links if you want) that point to the fact that the enthalpy under uniaxial compression along z of a solid is simply given by:
H=U+PzV
This appears to make sense as during uniaxial compression the Pz pressure component is the only one doing work (zero transverse strain). If you do a second subsequent uniaxial compression (along y say), then by the same logic the enthalpy should be given by U+PyV. However at the starting point of this second uniaxial compression the enthalpy is then given simultaneously by U+PzV and U+PyV, which can't possibly be true for general non-hydrostatic stress conditions. Hence my question is: is this formulation of the enthalpy valid only starting from equilibrium and doing only one uniaxial compression, or is it valid for general non-hydrostatic conditions?
Many thanks,
Gabriel
Science news on Phys.org
Further to my previous post, the reason why I'm interested in this is beacuse I would like to be able to calculate the transition parameters of a pressure-induced phase transition under non-hydrostatic stress conditions. Basically I have an energy surface of the material calculated with DFT, and I would like to be able to calculate the enthalpy at any point on this surface including the points away from the hydrostat, in order to find the enthalpy curves across the two phases involved in the phase transition and from their intersection the transition pressure. However I have the impression from the literature that the theory of thermodynamics under non-hydrostatic stress is still a source of confusion
Are you talking about elastic solids, that are capable of storing deformational energy? If so, are you confining the discussion to small strains?
Yes, I am indeed talking about elastic solids (no plasticity involved), and ideally I would like to derive a well-defined function of state equivalent to the enthalpy which is capable of determining phase equilibrium under non-hydrostatic stress and that reduces to the conventional definition U+pv when conditions are set back to hydrostatic.
I have attached a copy of the cold energy surface as a function of lattice geometry that I'm working with. The hydrostat is the dotted line and there the enthalpy is given trivially by U+pV, but everywhere else conditions are non-hydrostatic. The standard definition of enthalpy under such non-hydrostatic conditions given in textbooks like Landau and Lifgarbagez is:
H=U+ V_0 \sum_{i} \sigma_i \epsilon_i
where V_0 is the equilibrium volume and sigma and epsilon are the stress and strain tensors respectively. This is only valid for small strains, but the main problem is that it is incomplete: it is of the form U+P \Delta V, and hence a term equivalent to V_0 \Delta P is missing, but it is not trivial what form this term should have under non-hydrostatic conditions. This made me think that paths of uniaxial compression could provide the key for finding a well-defined function of state at each point on the surface
I forgot to mention: the strains I'm dealing with are finite and anisotropic, as you can see in the energy surfce
Sorry, g_mogni. I feel like I'm in a little over my head on this one. If you are considering phase transitions, the usual thermodynamic function to work with the the Gibbs free energy. As you probably know, during a phase transition, this is the same (per unit mass) for both phases. If no phase transition were involved, then there would be a strain energy function that would characterize the deformational mechanics, even at large deformations. The strain energy is a function of the three invariants of the Cauchy Green tensor.
chet
I know that the usual function to find phase equilibrium is the Gibbs free energy, but in my case the energy surface is calculated at 0K, hence G reduces to the enthalpy. On paper the problem is simple: how to find a way to generalise the PV term to non-hydrostatic stress, but it could be that there is no solution as I haven't been able to find any clear answers in the literature yet
Anyway, thanks for the help
I have attached another version of the energy surface that shows the trajectory of the line of uniaxial compression along z (those along y and x of course lie outside the plane of the plot) in the form of the red line. The dotted lines are contours of constant shear stress. I'm fairly certain that if you start from the equlibrium position (red dot), the enthalpy along the uniaxial line is given simply by U+pzV, but of course being able to calculate the enthalpy along just one line outside of the hydrostat doesn't help much.
Hence I was wondering if one could in theory reach any point on the surface by considering the line of uniaxial compression crossing it, which in general will intersect the hydorstat at positions away from equilibrium, and use the same formula U+pzV. In this case the problem of how to find the enthalpy everywhere on the surface would be solved. I was wondering if anyone had ever come across a similar problem
Check out the Continuum Mechanics literature. Continuum Mechanics and Thermodynamics. I'm very confident that they have successfully analyzed this.
Chet
In general you have to generalize H=U+pV to [itex]H=U+sum_ij \sigma_{ij} \epsilon_{ij} [/itex], where σ is the stress tensor and ε the strain tensor.
Yes, I have come across that formula in Landau and Lifgarbagez "Theory of Elasticity". The problem with it is that only writing the stress-strain term leaves it incomplete: if you revert the conditions back to hydrostatic, you are left with $U+P \Delta V$, since $V_0 (\varepsilon_x+\varepsilon_y+\varepsilon_z)=\Delta V$. Hence there is a term of the form $PV_0$ which is missing to obtain $U+PV$ again, but it's not clear what form this term should have under non-hydristatic conditions. Landau himself admitted this in the footnote on page 9 of his book on elasticity
Maybe this will help a little.
For an incompressible isotropic elastic solid, the strain energy per unit volume W can be expressed in terms of the 3 principal stretches for a given deformation λ1, λ2, and λ3 by
[tex]W=W(\lnλ_1,\lnλ_2,\lnλ_3)[/tex]
The principal stresses are related to the strain energy function by:
[tex]σ_j=\frac{\partial W}{\partial \lnλ_j}[/tex]
Do you happen to know an expression for the strain energy density under finite strains?
The strain energy density for finite strains is a function of the three invariants of the Cauchy Green tensor, or, equivalently, the three principal stretch ratios.
Sorry I'm not very familiar with the theory of elasticity for finite strains, but I just read that the three invariants that you mentioned are given by:
[itex] I=tr(C)=\lambda_1^2 +\lambda_2^2 +\lambda_3^2 [/itex]
[itex] II=\lambda_1^2 \lambda_2^2 +\lambda_1^2 \lambda_3^2 +\lambda_2^2 \lambda_3^2 [/itex]
[itex] III=det(C)=\lambda_1 \lambda_2 \lambda_3 [/itex]
Is this correct?
Thanks
Actually I could just use the small-strain approximation for the strain energy:
[itex]U=\frac{1}{2} \sigma_{ij} \varepsilon_{ij} [/itex]
and integrate the formula numerically across small deformational steps
Is this correct?
Thanks
Yes.
Only if you know the stress at finite strains.
See Mechanical Properties of Solid Polymers, Second Edition, I. M. Ward, Macmillan, pages 44 - 47.
chet
Thanks, I will have a look at that book in the library ASAP
Related to Enthelpy under uniaxial compression of solid
What is enthalpy under uniaxial compression of solid?
Enthalpy under uniaxial compression of solid is a thermodynamic property that measures the amount of energy released or absorbed by a solid when it is compressed in one direction. It takes into account both the internal energy and the work done by the compression.
How is enthalpy under uniaxial compression of solid calculated?
Enthalpy under uniaxial compression of solid is calculated by taking the difference between the final and initial values of enthalpy, which includes both the internal energy and the work done by compression. It can also be calculated using the specific heat capacity and change in temperature of the solid.
What factors affect the enthalpy under uniaxial compression of solid?
The enthalpy under uniaxial compression of solid is affected by factors such as the type of solid, its chemical composition, temperature, pressure, and the rate of compression. The crystal structure of the solid also plays a significant role in determining its enthalpy under compression.
How does enthalpy under uniaxial compression of solid relate to its elastic properties?
Enthalpy under uniaxial compression of solid is closely related to its elastic properties, such as Young's modulus and Poisson's ratio. These properties affect the amount of energy required to compress the solid and thus, impact its enthalpy.
Why is enthalpy under uniaxial compression of solid important in materials science?
Enthalpy under uniaxial compression of solid is an important property in materials science as it provides information about the energy required to compress a solid, which can be used to predict its behavior under different conditions. It also helps in understanding the mechanical strength and stability of materials, which is crucial in various engineering applications.
17K
  • Classical Physics
  • Quantum Interpretations and Foundations
  • STEM Academic Advising
