mgkii
- 138
- 42
Is anyone able to explain something to do with entropic force at a level I might be able to understand please! Ok... you need to know what level I'm at?
Formal Maths & Physics at high school (I'm 50, so distant past :-)
Informal Maths & Physics - lifelong interest. Consume a lot of youtube channels like 3Blue1Brown, PBS Spacetime, Mathlogger, Science Asylum, Numberphile (and would recommend them all!). I've read Edward Frenkel's book on Langlands Program and wished I could better understand the math rather than just the concepts (well - must of them!)
Summary - reasonable on concepts and breadth of knowledge... veeeery shallow on the math.
Sorry for the rambling start - onto my question.
I've been watching videos on / reading material on Entropic force and there's one aspect that I can't get my head around, which is tying to understand the *mechanism* by which (for example) heat is caused to flow out/in of rubber band is it stretched and relaxed?
The bits I think get
- There's no difference in internal energy between a polymer that has been stretched into a straight chain, or one that's in a curled state.
- There's a big difference in entropy - there's only 1 configuration for a straight polymer a very large number of possible configurations for a curled one
- Energy is put into the system when you stretch a rubber band (and released when it is relaxed).
- I even get that it is completely logical from a 2nd law POV for the stretched rubber band to heat up as you reduce the entropy of the band
- I'm almost certain that friction doesn't come into this - it seems plausible for the stretching argument, but as soon as you consider the relaxing band then you'd have to have some kind of "anti-friction" to cause the cooling.
QUESTION (finally)
If I have a rubber band in a stretched state at temperature X and suddenly release the tension allowing it to shrink back to it's normal state, the temperature of that band will reduce - quite noticeably. The internal energy of the polymer chains that make up that band remains unchanged (or so all the material tells me).
1. What is the mechanism by which energy from the surrounding area is drawn into the band, causing whatever is touching the band to cool?
2. Where is that energy stored if it's not in the internal energy of the individual polymer chains
Thank you for you patience whilst I got to my question!
Best Regards
Matt
QUESTION (finally)
Best Regards
Matt
