Entropy calculations involving integration (physical chemistry)
In summary: I have been struggling to understand this particular equation for weeks now, and I am at a loss as to where to even start. I would really appreciate if someone could walk me through the steps involved in integrating this equation, and maybe even explain what dqrev and CpdT actually stand for.In summary, the heat capacity of an ideal gas can be expressed as shown below. CP = (10 + 0.006T) J K-1 mol-1. The change in entropy when 4 moles of this gas is isobarically heated from 200 K to 300 K can be calculated by Step 1 of the solution, which is to integrate ∫dqrev/T. dQ = nCpd
anisotropic
59
This isn't a homework question per se, but more of a coursework question. Specifically, I'm a bit at a loss as to how to go about learning a particular section of the coursework for a physical chemistry (i.e. thermochemistry) class I am taking. The section in question is that pertaining to calculations involving entropy (S).
For example, take the following question:
The heat capacity of a given ideal gas can be expressed as shown below.
Calculate the change in entropy when 4 moles of this gas are isobarically heated from 200 K to 300 K.
Step 1 of the solution (as given by the solutions manual):
ΔS = ∫dqrev/T
Where are they getting this equation from? But more importantly, what is it actually saying, conceptually? I haven't done calculus in years, so I am more than rusty when it comes to integration, meaning I don't even understand what "dqrev" means. Thus, I can't just look at the given expression and figure it out for myself. The actual mechanics of working with integrals, I can figure out on my own; the conceptual part, and where equations are being derived from, not so much.
If someone could help me out, it would be appreciated. Note that I am not looking for a solution to the problem given, as I already have that. Rather, I am requesting an explanation as to why the steps that are involved actually work (an explanation of the integration shown above would be a great start).
For the record, the solution ends up converting dqrev to CpdT, and integrates from there (200 K to 300 K). But again, I don't know what dqrev signifies to begin with, so I can't really make sense of any further steps. I do know, however, that q signifies heat transfer in other questions, and "rev" signifies that it is a reversible process (i.e. theoretical), while T is obviously temperature.
ΔS = ∫dqrev/T
First you find a reversible process between the beginning and end states. That would be a quasi-static expansion from V = nR(200)/P to V = nR(300)/P so it is an expansion by 1.5 times.
Since T is changing over this path, you have to express Q as a function of T and integrate. The expression for Q as a function of T is, by definition, Q = nCpΔT. So dQ = nCpdT
So the change in entropy is :
[tex]\Delta S = \int_{T_0}^{T_f} dQ/T = \int_{T_0}^{T_f} nC_pdT/T[/tex]
That integral works out to:
ΔS = nCp ln(Tf/T0)
Entropy is defined in this way for reasons having to do with thermodynamics. You will need to take a course or read a good text in Heat and Thermodynamics to understand the concepts involved. Good luck!
Also, you may wish to post on the Classical Physics board on this subject.
AM
As elementary as this question is, can you please explain this part further? What are you actually doing when you integrate?
I assume if you graphed the function, on the y-axis is q, and on the x-axis is T. Graphically speaking, integration is finding the area under the function/curve from point T1 (300 K) to point T2 (400 K), correct? If so, what does the actual area under this curve represent? Is it the entropy, or the change in entropy?
Could you substitute "by definition" with "due to having the equation memorized"?
I am indeed taking a thermochemistry course, hence these questions. The problem is that the course is extremely condensed, and the notes are largely mathematical, with little time spent conceptually explaining what is going on, if at all. All the explaining is done mathematically, and given that my calculus is, as mentioned, in serious need of re-learning, I find myself understanding literally nothing during class.
The textbook is helpful, but only to a certain extent, as it also heavily emphasizes the use of formulas to explain concepts. These reasons all combine to lead me to post on this forum.
You are taking the area of a surface. In this case, you are adding up a whole lot of dQ/T s.
Change in entropy resulting from heat flow Q at temperature T is defined as Q/T.
So essentially you want to find the area under a graph that plots 1/T on the vertical axis and Q on the horizontal axis. If T was constant, this would be easy - it is just the area of a rectangle 1/T high and Q wide so it is just Q/T. But here 1/T is a curve. So you have to integrate to find the area.
Well, there is a reason for defining entropy that way. It is useful in analysing thermodynamic processes.
AM
First of all, it's great that you are seeking clarification and understanding on this topic rather than just looking for a solution to the problem. Understanding the concepts and principles behind the equations is crucial in science.
To start, let's break down the equation ΔS = ∫dqrev/T. This equation is a representation of the second law of thermodynamics, which states that the entropy of a closed system will either remain constant or increase over time. In this equation, ΔS represents the change in entropy, dqrev represents the reversible heat transfer, and T represents temperature.
To understand the concept of entropy, it is important to first understand the concept of energy. Energy is the ability to do work, and in thermodynamics, it is often measured in joules (J). Now, when energy is transferred from one system to another, it can either be in the form of heat (dq) or work (dw). Heat is the transfer of energy due to a temperature difference, while work is the transfer of energy due to a force acting over a distance.
In this specific example, we are dealing with a process that is isobaric (constant pressure), meaning that the pressure of the system remains constant as it is heated. This means that the only form of energy transfer is through heat (dq), and there is no work being done (dw=0). Therefore, we can rewrite the equation as ΔS = ∫dq/T.
Next, we need to understand what "rev" means in dqrev. In thermodynamics, a reversible process is defined as a process in which the system is always in equilibrium with its surroundings. This means that the process occurs infinitesimally slowly, without any friction or other forms of energy loss. In this case, dqrev represents the heat transfer that would occur in a theoretical, reversible process.
Now, let's look at the integral sign (∫). This is a mathematical symbol that represents integration, which is a mathematical operation used to find the area under a curve. In this case, we are integrating dqrev/T, which means we are finding the area under the curve of the heat transfer (dqrev) divided by the temperature (T).
Finally, we need to understand why the solution ends up converting dqrev to CpdT and integrating from 200 K to 300 K. In this case, CpdT represents the heat capacity of the gas, which is the amount of heat required to raise the temperature of
Related to Entropy calculations involving integration (physical chemistry)
1. What is entropy and why is it important in physical chemistry?
Entropy is a measure of the amount of disorder or randomness in a system. In physical chemistry, it is important because it helps us understand and predict the behavior of chemical reactions and systems. It is also a fundamental concept in thermodynamics and plays a crucial role in understanding the second law of thermodynamics.
2. How is entropy calculated in physical chemistry?
Entropy can be calculated using the formula S = k ln W, where S is the entropy, k is the Boltzmann constant, and W is the number of microstates of a system. This formula takes into account the probability of each possible state of a system and calculates the overall disorder of the system.
3. What is the relationship between temperature and entropy?
As temperature increases, so does the entropy of a system. This is because an increase in temperature leads to an increase in the number of possible microstates, thus increasing the overall disorder of the system. This relationship is described by the equation ∆S = ∆H/T, where ∆S is the change in entropy, ∆H is the change in enthalpy, and T is the temperature in Kelvin.
4. How do you incorporate integration into entropy calculations?
In some cases, it may be necessary to use integration to calculate the entropy of a system. This is often the case for continuous systems, such as gases or liquids. In these cases, the entropy can be calculated by integrating the Boltzmann distribution function over all possible states of the system.
5. Can entropy be negative?
Yes, entropy can be negative in certain cases. This usually occurs when there is a decrease in disorder or randomness in a system, such as in a chemical reaction that results in the formation of a more ordered product. However, the overall entropy of the universe must always increase, as dictated by the second law of thermodynamics.
