Parzeevahl
- 6
- Homework Statement
- 1 kg of water at 273 K is brought into contact with a heat reservoir at 373 K. When the water has reached 373 K, what is the entropy change of the water, of the heat reservoir, and of the universe?
- Relevant Equations
- dS=Cp*(dT/T)-nR*(dP/P)
dS=Cv*(dT/T)+nR*(dV/V)
Problem Statement: 1 kg of water at 273 K is brought into contact with a heat reservoir at 373 K. When the water has reached 373 K, what is the entropy change of the water, of the heat reservoir, and of the universe?
Relevant Equations: dS=Cp*(dT/T)-nR*(dP/P)
I am assuming that the question means the water is in a container or something, so its pressure and/or volume shouldn't change on heating. Then dP=dV=0.
Now, at 273 K and 373 K, the specific heat of water, Cp, is nearly the same, So, I take it as a constant = 4217 J/(kg.K).
So, dS=Cp*(dT/T)
I have dT=373K-273K=100K, T=373K.
Putting values, I get dS=1130 J/K.
But I'm confused whether this is the entropy change of the reservoir or the water. The answer given in the book says that it is the entropy change of the reservoir, but I can't understand why. Also, if this is the entropy change of the reservoir, when how do I calculate that of the water?
So, dS=Cp*(dT/T)
