Entropy change in an RC circuit
In summary: Delta S_{univ}=\frac{\varepsilon'}{2\varepsilon.c}\cdot q_{f}^{2}-\frac{\varepsilon'}{2\varepsilon.c}\cdot q_{f}^{2}+\frac{q_{f}^{2}}{2c.T_{0}}=\frac{q_{f}^{2}}{2c.T_{0}}
yamata1
61
Hello,I would like some help for a problem
Initially:At t=0 [/B]the cylindrical capacitor of capacitance [itex]c=\frac{\epsilon s}{d}[/itex] (d the distance between the 2 electrodes and s their surface; [itex]\epsilon = \epsilon(T)[/itex] is the dielectric permittivity) is discharged and we close the circuit and charge isothermally the cylindrical capacitor until it has a [itex]c*v[/itex] charge.
The current is [itex]i=\frac{dq}{dt}[/itex] and the voltage is v(t), the electric charge of the capacitor is [itex]q(t)=c*v(t)[/itex].
We have an RC circuit receiving work [itex]W[/itex] from a generator of voltage [itex]v[/itex] and energy [itex]Q_{exchanged}[/itex] from a thermal reservoir (thermostat) of [itex]T_0[/itex] Kelvin,the circuit has its entropy change[itex]\Delta S_{in}[/itex] during the charging.
We have [itex]C_q[/itex] the heat capacity for a constant charge q and [itex] \lambda= \frac{qT \epsilon'}{\epsilon c}[/itex] another coefficient in the equation :
[itex]TdS_{in}= C_q dT + \lambda dq[/itex] (1)
What is the entropy of the universe [itex]\Delta S_{univ}[/itex] equal to ?
Does [itex]C_q[/itex] depend on [itex]q[/itex] ?
[itex]\Delta S_{thermostat}=\frac{Q_{exchanged}}{T_0}[/itex]
If we integrate [itex] C_q[/itex] over T ,I think q does appear in the formula for [itex]C_q[/itex] but it's not a variable I think.To find [itex]\Delta S_{in}[/itex] we divide the equation (1) by T then integrate [itex] \frac{\lambda}{T}[/itex] over q from 0 to q=cv.
[itex]\Delta S_{univ}=\Delta S_{thermostat}+\Delta S_{in}[/itex]
I would like to know how to express [itex]\Delta S_{thermostat}[/itex] and it's sign. Thank you.
What physical physical picture you are trying to work with? That is, what phenomenon are you interested in? It seems you have the capacitor bathed in a temperature reservoir. Why?
I want to know how to express the entropy change , I think the entropy change of the universe is 0 but I'm not sure what the equation is.The RC circuit is getting heat from the reservoir and work from the generator,I'm guessing it's to make it a reversible process.
I am not sure, but I suspect you are confused. Ordinarily one does not consider heat when analyzing an RC circuit, and the capacitance of a capacitor does not vary much with temperature. I am not so sure that the net change in entropy of the universe is zero; For irreversible processes, entropy increases.
Generally the flow of current through a circuit with resistance is not a reversible process. The resistors give off heat but never absorb heat.
Likes yamata1
This is pretty advanced thermodynamics. I can only give you some ideas:
Since the capacitor is being charged isothermally, dT = 0 and you are left with dS = [itex]\lambda dq[/itex]/T = (ε'/εc)q dq. You didn't say what ε' and c are. But your eq. (1) is of course a form of the Maxwell "2nd T dS equation" so there must exist a coefficient representing the change of polarization with T ( related by the state equation). So maybe ε' = dε/dT and ΔSdielectric = (ε'/εc) q dq from q=0 to q = Cv.
Then the total change in entropy of the universe is just ΔSdielectric - ΔSthermostat.
Sorry, not very definite; hope others will do better.
I think I have an explanation :
The generator gives the system {resitance,capacitor} the electric energy :
The capacitor charges itself by en absorbing half ( the work ##W=\int vdq##). The difference represents the lost energy through the Joule effect :
This energy is received through heat by the heat reservoir at fixed temperature ,which increases the entropy by :
Accouting for the resistance, we have :
[tex] \Delta S_{univ}=\frac{\varepsilon'}{2\varepsilon.c}\cdot q_{f}^{2}-\frac{\varepsilon'}{2\varepsilon.c}\cdot q_{f}^{2}+\frac{q_{f}^{2}}{2c.T_{0}}=\frac{q_{f}^{2}}{2c.T_{0}}[/tex]
there is a creation of entropy caused by the Joulet effect which is an irreversible phenomenon as Gene Naden wrote
The power received by the heat reservoir is the power produced by the Joule effect :
  • ile_TEX.cgi?\frac{dS_{univ}}{dt}=\frac{P_{Joule}}{T_{0}}=\frac{r}{T_{0}}.gif
Related to Entropy change in an RC circuit
1. What is an RC circuit?
An RC circuit is a circuit that contains a resistor (R) and a capacitor (C) connected in series or parallel. The resistor determines the flow of current in the circuit, while the capacitor stores and releases electrical charge.
2. What is entropy change in an RC circuit?
Entropy change in an RC circuit refers to the gradual loss of energy or disorder within the circuit over time. This can be measured by the increase in the value of entropy, which is a measure of randomness or disorder.
3. How is entropy change related to the RC time constant?
The RC time constant is a measure of how quickly the capacitor in an RC circuit can charge or discharge. As the capacitor charges or discharges, the entropy within the circuit increases due to the loss of energy. Therefore, the entropy change is directly related to the RC time constant.
4. What factors affect the entropy change in an RC circuit?
The main factors that affect the entropy change in an RC circuit are the resistance and capacitance values, as well as the voltage applied to the circuit. Higher resistance and capacitance values, as well as higher voltages, will result in a larger entropy change over time.
5. How is entropy change in an RC circuit calculated?
The entropy change in an RC circuit can be calculated using the formula ΔS = Q/T, where ΔS is the change in entropy, Q is the heat transfer, and T is the temperature. In an RC circuit, the heat transfer is equivalent to the energy lost through the resistor, and the temperature is the average temperature of the circuit.
