Entropy change of a bullet hitting water
To calculate the change in entropy when a lead bullet hits water, the bullet's kinetic energy of 1250 J is converted into thermal energy. The bullet, initially at 150 degrees Celsius, comes to thermal equilibrium with the water at 25 degrees Celsius. The total thermal energy is absorbed by the water, raising its temperature, while the bullet cools down to match the water's temperature. Since entropy is a state function, the intermediate temperatures do not need to be considered for the calculation. Understanding that the system reaches equilibrium is crucial for determining the entropy change.
KaiserBrandon
Calculate the change in entropy when a lead bullet of mass 10 grams traveling at 500 m/s hits a very large volume of water. Assume that the bullet was initially at 150 degrees Celsius and the water was at 25 degrees Celsius.
K=\frac{1}{2}\,{{\it mv}}^{2}
\Delta S={\frac {\delta Q}{T}}
So I calculated the kinetic energy of the bullet to be 1250J. If the bullet is stopped by the water, that 1250J becomes thermal energy. Now this is where I'm stuck. I'm not exactly sure how to determine how much of that thermal energy is absorbed by the bullet, and how much by the water.
In the end, it's all absorbed by the water, and the bullet also ends up at 25 degrees C. And since entropy is a state function, you don't need to worry about intermediate temperatures. Does this help?
ok, I wasn't sure if the system was allowed to reach equilibrium or not.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
