Entropy change of a reservoir after heating something up
In summary: Great, thanks for your help. So doing the entropy integral for a fixed temperature, I get:ΔS = ∫dQ/T = (1/T) * C(ΔTsilver) = (1/373)*C*100 = -61.66This number is massive compared to the integral I did above for the silver with a varying temperature. Could you perhaps tell me which number is wrong and why?You got the first part correct : 0.312CBut, it looks like you made an arithmetic error (or something) in the second part. I get -0.268C.
Robsta
88
1kg of silver is heated by a large heat reservoir at 373 K from 273K. Calculate the change of entropy in:
a) the silver
b) the reservoir
c) the universe.
ΔS = ∫dQ/T
calculating the change in the silver first
ΔS = ∫dQ/T
= C∫dT/T
= Cln(T2/T1)
= 0.312
This is fine, I understand it. Now I need to work out the entropy change in the large reservoir. Since the change happens spontaneously, it isn't reversible and the entropy of the universe increases. This means that I can't just take the negative of the change in the silver.
Since the temperature of the reservoir doesn't change, is there no effective change in the entropy? This obviously shouldn't be the case because it would violate the second law. I'd appreciate any insight that can be offered.
The temperature of the reservoir doesn't change appreciably, but it does lose the same amount of heat that the silver absorbs. As far as the reservoir is concerned, because the heat transfer took place at constant temperature, it thinks it experienced a reversible change (actually, it really did experience a reversible change). On the other hand, the silver experienced an irreversible change (since there were substantial temperature gradients in the silver during the transient heating). The combined change in both the silver and the reservoir must be positive because of the irreversibility in the silver. So you have enough information now to determine the entropy change of the reservoir, and the overall entropy increase for the combination (i.e., the universe).
Chet
= -61.66
Chet
Related to Entropy change of a reservoir after heating something up
1. What is entropy change of a reservoir?
Entropy change of a reservoir refers to the measure of the randomness or disorder of the molecules within the reservoir. It is a thermodynamic property that describes the distribution of energy within a system.
2. How does heating something up affect the entropy change of a reservoir?
When something is heated up, the molecules within it gain energy and become more disordered. This leads to an increase in the entropy change of the reservoir as the molecules become more randomly distributed.
3. Is entropy change of a reservoir always positive when something is heated up?
Yes, according to the Second Law of Thermodynamics, the entropy of an isolated system can never decrease. Therefore, the entropy change of a reservoir will always be positive when something is heated up.
4. Can the entropy change of a reservoir be negative?
No, the entropy change of a reservoir cannot be negative as it represents the degree of randomness or disorder within the system. A negative value would imply a decrease in randomness, which is not possible according to the Second Law of Thermodynamics.
5. How does the size of a reservoir affect the entropy change after heating something up?
The size of a reservoir does not directly affect the entropy change after heating something up. However, a larger reservoir may be able to absorb more heat without a significant change in its temperature, leading to a smaller increase in entropy change compared to a smaller reservoir.
