Entropy due to this irreversible process
The discussion focuses on calculating the entropy generated due to irreversibilities in an adiabatic container with water and a propeller. It establishes that the change in internal energy is equal to the work done by the propeller, leading to the relationship dS = dU/T. The participants emphasize that since entropy is a state function, the change in entropy can be determined using a reversible path, allowing for the calculation of heat transfer as dS = δQ_rev/T. The final expression for entropy change is derived as ΔS = mC ln(T_f/T_i), where T_f is the final temperature after work is done on the water. This analysis highlights the importance of reversible processes in thermodynamic calculations.
Simobartz
There is an adiabatic container filled with water. The volume of the container is fixed and inside the continer there is a propeller electrically connected to the outside. If the work done by the propeller on the water is ##\delta W_{prop}##, what is the entropy generated due to irreversibilities?
$$dU=TdS-PdV$$
I think the solution is:
$$dU=\delta W_{prop}$$
$$dU=TdS-PdV$$
$$dV=0$$
then, $$TdS=\delta W_{prop}$$ and so $$dS=dU/T$$
and by the way, it correct to say that, if the transformation between the initial and the final state would happen in a reversible way then the heat transfer could be calculated as
$$dS=\delta Q_{rev} /T$$
$$\delta Q _{rev}=TdS$$
$$\delta Q_{rev}=\delta W_{prop}$$
Simobartz said:
Homework Statement:: There is an adiabatic container filled with water. The volume of the container is fixed and inside the container there is a propeller electrically connected to the outside. If the work done by the propeller on the water is ##\delta W_{prop}##, what is the entropy generated due to irreversibilities?
Relevant Equations:: $$dU=TdS-PdV$$
$$dU=TdS-PdV$$
$$dV=0$$
You have the right idea. Since entropy is a state function, entropy change does not depend on the process in going from the initial state to the final state. So it is a matter of finding a convenient reversible path from initial to final state and calculating ##\Delta S = \int_{i}^{f}\frac{dQ_{rev}}{T}## along that path.
The equivalent reversible path would be heat flow into the water increasing internal energy by an amount equal to the work done.
Since W=Q=mC(Tf-Ti), [where m is the mass of the water and C is its specific heat capacity], ##T_f=T_i+W/mC## and ##dW = dQ = mCdT##.
##\Delta S = \int_{T_i}^{T_i+W/mC}\frac{dQ_{rev}}{T} = \int_{T_i}^{T_i+W/mC}\frac{mCdT}{T} ##
So:
##\Delta S = mC\ln\left(\frac{T_i+W/mC}{T_i}\right)##
AM
