Entropy increase in dissipative systems
In summary, In this steady state dissipative system, the additional constraint causes a larger heat dissipation and lower final state kinetic energy. The entropy increase is a minimum, subject to the constraints. I always thought that the entropy increase should be maximal, subject to the constraints. Which is correct?"
Bob S
4,662
Consider the following steady-state dissipative system. A mountain stream flowing 1 liter per second drops 100 meters over rocks and boulders, and at the bottom has both a temperature increase and a residual kinetic energy (velocity). The sum of the temperature rise and the kinetic energy is 980 watts. Maximum entropy increase would maximize the temperature rise, but because the stream has kinetic energy at the bottom, the temperature rise is not maximum. If I added rocks to the flow, the system constraints and the temperature rise would be higher. What is the over-riding principle that minimizes the entropy increase (maximizes the kinetic energy), based on the constraints of the system?
Science news on Phys.org
Bob S
The over-riding principle that minimizes the entropy increase in this system is the principle of energy conservation. This principle states that in a closed system, energy cannot be created or destroyed, but can only be transformed from one form to another. In the case of the mountain stream, the initial potential energy of the water at the top of the mountain is converted into kinetic energy as it flows down the rocks and boulders, and this kinetic energy is then partially converted into thermal energy at the bottom. However, the total amount of energy (980 watts) remains constant.
Therefore, in order to minimize the entropy increase, the system must maximize the conversion of potential energy into kinetic energy. This is because kinetic energy is a more ordered form of energy than thermal energy, and therefore has a lower entropy. By adding rocks to the flow, the system constraints are changed, allowing for a more efficient conversion of potential energy into kinetic energy, resulting in a lower overall entropy increase.
In summary, the principle of energy conservation is the driving force behind the minimization of entropy increase in dissipative systems. By maximizing the conversion of potential energy into kinetic energy, the system is able to maintain a higher level of order and decrease the overall entropy increase.
Related to Entropy increase in dissipative systems
1. What is entropy increase in dissipative systems?
Entropy increase in dissipative systems refers to the tendency of a system to become more disordered over time due to energy dissipation. This means that the system's energy is being converted into less useful forms, leading to an increase in entropy.
2. How does entropy increase in dissipative systems affect the overall stability of the system?
The increase in entropy can lead to a decrease in the overall stability of the system. This is because the system becomes more disordered and less organized, making it more vulnerable to external disturbances and less able to maintain its current state.
3. What are some examples of dissipative systems?
Examples of dissipative systems include chemical reactions, weather patterns, and living organisms. In these systems, energy is constantly being exchanged with the environment, leading to an increase in entropy.
4. How does the second law of thermodynamics relate to entropy increase in dissipative systems?
The second law of thermodynamics states that the total entropy of a closed system will always increase over time. In dissipative systems, energy is constantly being exchanged with the environment, leading to an increase in entropy and following the principles of the second law.
5. Can entropy increase in dissipative systems be reversed?
Entropy increase in dissipative systems cannot be reversed. This is because energy dissipation is a natural and irreversible process that occurs in all systems. However, some systems may be able to maintain a low level of entropy for a period of time, but eventually, entropy will always increase.
