Entropy of spin-1/2 Paramagnetic gas
In summary: I think it gives a result for ##S## in terms of ##U##, but it might not be the most efficient way to do it. If you're not sure, you could try different methods, see which one gives you the result you're looking for the fastest.
curious_mind
41
Find the Entropy of spin-1/2 Paramagnetic gas
## S = k_B \ln \Omega(U) ##
## S = \Sigma_r P_r \ln P_r ##.
As we know, dipole can be only arranged either parallel or anti-parallel with respect to applied magnetic field ## \vec{H} ## if we are to use quantum mechanical description, then parallel magnetic dipoles will have energy ## \mu H ## and anti-parallel magnetic dipoles have energy ## -\mu H##.
Method 1:
Let the number of magnetic dipoles with ## m_s = + \frac{1}{2} ## spin are ## n_{\uparrow} ## and number of magnetic dipoles with ## m_s = - \frac{1}{2} ## spin are ## n_{\downarrow} ##. Total number of dipoles are ## N = n_{\uparrow} + n_{\downarrow} ##. So, ## n_{\downarrow} = N - n_{\uparrow} ##. And, total internal energy ## U = n_{\uparrow} \mu H - n_{\downarrow} \mu H = ( 2 n_{\uparrow} - N ) \mu H \Longrightarrow n_{\uparrow} = \dfrac{1}{2} \left( \dfrac{U}{\mu H} + N \right) ##.
Now, total number of microstates having internal energy U will be $$\Omega (U) = \dfrac{N!}{n_{\uparrow} ! ( N - n_{\uparrow} ) !}$$. Using ## S = k_B ln \Omega(U) ##, we get ## S = k_B [ \ln N! - \ln n_{\uparrow} ! - \ln (N - n_{\uparrow}) ! ] ##. Using stirling approximation, $$S = k_B [ N ln N - N - (n_{\uparrow} \ln n_{\uparrow} - n_{\uparrow}) - ( (N - n_{\uparrow}) \ln (N - n_{\uparrow}) - (N - n_{\uparrow}) ) ] $$. Upon simplifying this we get $$S = k_B \left[ N \ln N - \left( \dfrac{N \mu H- U }{2 \mu H} \right) \ln \left( \dfrac{N \mu H- U }{2 \mu H} \right) - \left( \dfrac{N \mu H+ U }{2 \mu H} \right) \ln \left( \dfrac{N \mu H+ U }{2 \mu H}\right) \right]$$.
Method 2:
Using expression ## S = N k_B \Sigma_r P_r ln P_r ##, we have ## S = N k_B [ p \ln (p) + (1-p) \ln (1-p) ] ##. If we take thermodynamic probability ## p = \dfrac{e^{\frac{- \mu H}{k_B T}}}{e^{\frac{- \mu H}{k_B T}} + e^{\frac{\mu H}{k_B T}}} ##. Upon simplifying this, I do not seem to get above expression. Answer comes in terms of hyperbolic functions.
Now, my confusion is - which expression is correct one - method 1 or method 2 ? Answer is given - $$S = N k_B \left[\left( \dfrac{-N \mu H+ U }{2 N \mu H} \right) \ln \left( \dfrac{N \mu H+U }{2 \mu H} \right) - \left( \dfrac{N \mu H+ U }{2 N \mu H} \right) \ln \left( \dfrac{N \mu H- U }{2 N \mu H}\right) \right]$$. . Now, I am not getting this expression from above ones. This is nearer from first method, but it does not seem obtainable from first method as well. I think Answer can be incorrect.I am confused about which formula to use. Of course, only one answer is there. But I require clarification about which step I can proceed with under what Conditions.I am beginner in this subject. So I want clarification like, in what limit does this stirling approximation apply ? When temperature tend toward infinity or something else ? I have seen expression ## S = N k_B \ln 2 ## for infinite temperature limit. and ##S = 0## for ## T \rightarrow 0 ##.
Kindly share any relevant link or resource which address this issue. I am looking into Statistical Mechanics book by F.Rief, it has section in 6th chapter for using approximations for canonical ensembles. It describes that calculation of number of microstates ## \Omega(E) ## in range ## E < E_r < E + \delta E## can be difficult to calculate. Is this related to this? I don't think but still mentioning in case I am missing out something.
Thanks.
I did not read everything, but a quick suggestion for method 1: try to express the whole thing in terms of ##\dfrac{U}{\mu H}## and factor out (it's normal if some of your factorizations won't lead anywhere) ##N##. I don't know the exact expression of the entropy, and since you have doubt on the solution given, you might want instead to compare with the internal energy which has a very simple expression:
U = -N\mu H\tanh\left(\dfrac{\mu H}{k_BT}\right).
First try my suggestion, then compute ##\beta :=\dfrac{1}{k_BT} = \dfrac{\partial \ln\Omega(U)}{\partial U}##, and finally express ##U## in terms of everything else. One useful relation: ##\mathrm{argtanh}\left(x\right)=\dfrac{1}{2}\ln\left(\dfrac{1+x}{1-x}\right).##
First method uses the microcanonical ensemble while second uses the canonical ensemble, that's the main difference ... For a system of spins, we usually use the first method when we ... don't know yet the canonical ensemble: second method is actually much faster. I'm pretty sure your coursebook (in particular Reif) explains it very well.
Likes vanhees71 and curious_mind
I'll add a couple of more comments. Your answer for ##S## as a function of ##U## looks ok to me.
See what your result gives for ##S## in the limit ##T = 0## and the limit ##T = \infty##. For ##T = 0## what do you expect for the value of ##U##? What does this value of ##U## give for ##S##? Repeat for ##T = \infty##.
What does their result for ##S## give in these limits?
Likes yezia
At ## T=0 ## I expect ##U=0##, is it correct ? And using ##U=0## and expression of method 1 of microcanonical ensemble(as pointed out by @yezia ) I am getting ## S = N k_B \ln 2## .
Ok then i wrote in the question, as ## T \rightarrow 0 ## , ##S =0## would not be correct then.
For ## T \rightarrow \infty ## , I am not sure about behavior of ## U ##. I am still confused about this. I lack some basics.
In microcanonical ensemble, ##U## is fixed, right ? So expressions of microcanonical ensemble will have ##U## in it and thermodynamic functions of canonical ensemble will have ##T## in it. This thing I missed totally.
Yes, these things explained in book. But often books are large and you miss lot of things despite reading them.
When ##T\rightarrow 0##, the internal energy is not 0. ##T = 0## corresponds to the state of minimal energy, and in this case, all the spins must be anti-parallel to the magnetic field (do you see why ?). What is the expression of ##U(T=0)## now that you know this ?
On the other hand, when ##T\rightarrow \infty## - important: you cannot physically say that a variable ##x## approaches infinity, we usually introduce characteristic variables ##x^*## (it is all a matter of dimensions) and judge "big" or "small" comparatively to these -, you can consider each spin as totally "indepedent"; they do as they want, and they have same probability of being up or down (do you understand why ?). Knowing this, what would ##U(T\gg T^*)## compute to ?
Other tip: don't forget the expression ##S\propto \ln\Omega##. At 0 temperature, how many states are accessible by the system ? At very high temperature, each spin has 2 equiprobable state; how many states are therefore accessible by the whole system ? This can help you understand the value of the entropy at the mentioned limits.
You can moreover look at the graph of ##U=U(T)## (expression in my first message) to enhance your intuition and understand better the asymptotic behaviour of ##U(T)##.
That's pretty much it yes! It is perfectly normal to not understand everything at first when reading a big book as Reif's :)
Likes TSny and curious_mind
The first formula is a function of ##U##, so it works for a fixed energy. The second, as you wrote yourself, involves temperature, so it works for fixed ##T##. Which to use depends on the particular situation at hand.
It works when ##N## is big. The approximation is better than 1% already for ##N=100##.
You can moreover look at the graph of ##U=U(T)## (expression in my first message) to enhance your intuition and understand better the asymptotic behaviour of ##U(T)##.That's pretty much it yes! It is perfectly normal to not understand everything at first when reading a big book as Reif's :)
Ok, so , since minimum energy will take place at T=0, ##U = - N \mu B H## that's why all diploes will align anti-parallely. For ## T \rightarrow \infty ## I think I understood from your description and your previous first reply.
Thanks. :)
According to what I learned from this article (page 23-24), the first one is an approximation of the second one, when ##\Omega(E)## increases rapidly and ##E_*## gives the maximum value of ##\Omega(E)e^{-βE}##. So the partition function ##Z≈\Omega(E_*)e^{-βE_*}##, thus ##S≈k_Bln\Omega(E_*)##.
Likes curious_mind
FAQ: Entropy of spin-1/2 Paramagnetic gas
What is the definition of entropy in the context of spin-1/2 paramagnetic gas?
In the context of spin-1/2 paramagnetic gas, entropy refers to the measure of disorder or randomness of the system. It is a thermodynamic property that describes the distribution of energy among the particles in the gas.
How is entropy related to the spin of particles in a paramagnetic gas?
In a spin-1/2 paramagnetic gas, the entropy is directly related to the number of particles with a certain spin orientation. As the number of particles with different spin orientations increases, the entropy of the system also increases.
What is the role of temperature in the entropy of a spin-1/2 paramagnetic gas?
Temperature plays a crucial role in determining the entropy of a spin-1/2 paramagnetic gas. As the temperature increases, the particles in the gas gain more thermal energy and are able to occupy a larger range of energy states, leading to an increase in entropy.
How does the entropy of a spin-1/2 paramagnetic gas change with changing magnetic field?
The entropy of a spin-1/2 paramagnetic gas is directly proportional to the strength of the magnetic field. As the magnetic field increases, the particles in the gas align their spins more with the field, resulting in a decrease in entropy.
Can the entropy of a spin-1/2 paramagnetic gas ever reach zero?
No, the entropy of a spin-1/2 paramagnetic gas can never reach zero. This is because even at absolute zero temperature, the particles in the gas will still have some residual thermal energy, allowing for a non-zero number of spin orientations and therefore a non-zero entropy.
