I Entropy reversal in an infinite static universe?
Entropy reversal in an infinite static universe is debated through the lens of the Poincaré recurrence theorem, which suggests that entropy could reverse if the universe has a finite volume. Leonard Susskind proposes a scenario where vacuum decay leads to a static universe, but he argues that this would prevent recurrence. Conversely, some discussions suggest that a static universe without accelerated expansion could still allow for recurrence, as it would not reach maximal entropy. The key issue revolves around whether the universe's phase space has a finite volume, which is influenced by the presence of a cosmological constant. Ultimately, the possibility of a closed universe topology may provide a framework for understanding these dynamics.
Suekdccia
TL;DR Summary
As far as I know, entropy could be reversed by the Poincaré recurrence theorem if it had a finite horizon given by some amount of vacuum energy causing an accelerating expansion.
However, I found this lecture by Leonard Susskind () where he tells a way through which the vacuum could decay into a vacuum state with no energy and therefore no expansion would occur. In this case, we would have a static universe. However, he says that in this case no recurrence would take place.
But, in this answer to one similar question on another physics-discussion site (Could any new structures be formed after the heat death of the universe?), it says that in a static universe with no accelerated expansion (and therefore no cosmological constant) the Poincarré recurrence theorem would hold. And also, I understand that in a non-accelerating expanding universe there would be no maximal entropy reached so the recurrence should occur.
So, what am I missing here?
Space news on Phys.org
For the Poincare recurrence to exist, the essential requirement is that the phase space of all possible initial conditions has a finite volume. (In the quantum version, it translates to the finite dimension of the Hilbert space.) If there is a cosmological constant, then the universe has the horizon which makes it effectively finite, so the Poincare recurrence seems plausible. If there is no cosmological constant, and hence no horizon, the Poincare recurrence requires some other mechanism by which the universe has a finite volume. A reasonable possibility is that the universe is closed, i.e. that its spatial topology is a 3-dimensional sphere. I didn't watch the video, but I suspect that Susskind had such a closed universe in mind.
Abstract The Event Horizon Telescope (EHT) has significantly advanced our ability to study black holes, achieving unprecedented spatial resolution and revealing horizon-scale structures. Notably, these observations feature a distinctive dark shadow—primarily arising from faint jet emissions—surrounded by a bright photon ring. Anticipated upgrades of the EHT promise substantial improvements in dynamic range, enabling deeper exploration of low-background regions, particularly the inner shadow...
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
Title: Can something exist without a cause? If the universe has a cause, what caused that cause? Post Content: Many theories suggest that everything must have a cause, but if that's true, then what caused the first cause? Does something need a cause to exist, or is it possible for existence to be uncaused? I’m exploring this from both a scientific and philosophical perspective and would love to hear insights from physics, cosmology, and philosophy. Are there any theories that explain this?
