Epsilon delta continuity of 1/x at x=1
In summary: So assume \epsilon < 1. Then we can multiply the inequalities together to get1 - \epsilon < \frac{1}{1 + \delta}\frac{1}{1 - \delta} < \frac1{x^2} < \frac{1}{(1 - \delta)^2} < 1 + \epsilonWe need to solve1 + \epsilon < \frac{1}{1 - \delta}\frac{1}{(1 - \delta)^2} = \frac{1}{1 - \delta} - \frac{1}{(1 - \delta)^2} < 1 - \epsilonNote that if 0 < \delta \leq 1 - \
Avatrin
245
This isn't really homework; It's just something that has been bothering me ever since I first learned calculus because I suck at epsilon-delta proofs.
Show that 1/x is continuous at x=1
If |x-a|<δ
Then |f(x)-f(a)|<ε
x<δ+1
1/x<ε+1
(ε+1)x>1
1/(ε+1)<x<δ+1
*starts crying*
You appear to have a confused idea of what limits are. You cannot just choose δ and
ε independently. The definition of "limit" is
[itex]\lim_{x\to a} f(x)= L[/itex] if and only if given [itex]\epsilon> 0[/itex] there exist [itex]\delta> 0[/itex] such that if [itex]|x- a|< \delta[/itex] then [itex]|f(x)- L|< \epsilon[/itex].
That is, [itex]\delta[/itex] will typically depend upon [itex]\epsilon[/itex]. The simplest way to prove a limit is to start from [itex]|f(x)- L|<\epsilon[/itex] and use that to derive a value for [itex]\delta[/itex]. As long as every step is "reversible that shows we can from [itex]|x- a|< \delta[/itex] to [itex]|f(x)- L|< \epsilon[/itex].
Here, f(x)= 1/x, a= 1, and L= 1. So, given [itex]\epsilon> 0[/itex] we want to get [itex]|1/x- 1|< \epsilon[/itex] (notice the absolute value- you didn't have that). That is the same as [itex]-\epsilon< (1/x)- 1< \epsilon[/itex] which is the same as [itex]-\epsilon< (1- x)/x< \epsilon[/itex]. As long as x is close to 1 ([itex]\delta[/itex]< 1) x> 0 so [itex]-x\epsilon< 1- x< x\epsilon[/itex].
You need to show that for all [itex]\epsilon > 0[/itex] there exists [itex]\delta > 0[/itex] such that if [itex]|x - 1| < \delta[/itex] then [itex]|1/x - 1| < \epsilon[/itex].
We will clearly need [itex]0 < \delta < 1[/itex] (or else 0 will be in our interval). Now 1/x is strictly decreasing for [itex]x > 0[/itex] (this is a consequence of [itex]\mathbb{R}[/itex] being an ordered field), so for [itex]0 < 1 - \delta < x < 1 + \delta[/itex] the following inequality is true:
[tex]\frac{1}{1 + \delta} < \frac1x < \frac{1}{1 - \delta}[/tex]
So if given [itex]\epsilon > 0[/itex] we can find [itex]\delta[/itex] such that
[tex]
1 - \epsilon < \frac{1}{1 + \delta} < \frac1x < \frac{1}{1 - \delta} < 1 + \epsilon
[/tex]
then we will be done. Note that if [itex]\epsilon \geq 1[/itex] then the left-most inequality is satisfied for any [itex]\delta > 0[/itex].
FAQ: Epsilon delta continuity of 1/x at x=1
What is the definition of epsilon delta continuity?
Epsilon delta continuity is a mathematical concept that describes the behavior of a function at a specific point. It states that a function f(x) is continuous at a point x=a if for any given value of epsilon (ε), there exists a corresponding value of delta (δ) such that for all values of x within δ units of a, the difference between f(x) and f(a) is less than ε.
How is epsilon delta continuity used to prove continuity?
Epsilon delta continuity is used to prove that a function is continuous at a specific point by showing that for any given value of ε, there exists a corresponding value of δ such that the distance between f(x) and f(a) is less than ε for all values of x within δ units of a. This shows that as x approaches a, f(x) approaches f(a), indicating continuity at that point.
Can epsilon delta continuity be applied to all functions?
Yes, epsilon delta continuity can be applied to all functions as long as the function is defined and has a limit at the point in question. It is a fundamental concept in calculus and is used to prove the continuity of various functions.
What is the significance of epsilon and delta in epsilon delta continuity?
The values of epsilon (ε) and delta (δ) represent the closeness of a function to its limit at a specific point. Epsilon represents the maximum allowable distance between the function and its limit, while delta represents the maximum allowable distance between the input and the point at which the limit is being evaluated.
How is epsilon delta continuity related to the concept of limits?
Epsilon delta continuity is closely related to the concept of limits. In fact, it is used to prove the existence of limits. The definition of epsilon delta continuity is based on the idea that as x approaches a certain value, the function approaches a specific limit, which is the foundation of limits in calculus.
