Epsilon-Delta definition property.
In summary, the function has a limit at which means that there exists a number such that for all x in D satisfying |x-a|<δ, the inequality |f(x)-L|<ε holds.
Alpharup
225
he
definition of the limit of a function is as follows:[5]
Let
be a function defined on a subset [PLAIN]https://upload.wikimedia.org/math/a/1/b/a1b67abab803e714098f3e69a33900da.png, let
be a limit point of [PLAIN]https://upload.wikimedia.org/math/f/6/2/f623e75af30e62bbd73d6df5b50bb7b5.png, and let
be a real number. Then
the function
has a limit
at
is defined to mean
for all [PLAIN]https://upload.wikimedia.org/math/b/0/f/b0f19c5714fe9f9891ed26ff783cf639.png, there exists a https://upload.wikimedia.org/math/1/c/b/1cb24dafc8035d2c720256620066ae73.png such that for all
in
that satisfy [PLAIN]https://upload.wikimedia.org/math/6/e/e/6ee6dc9ee03f04da6ff784b6eca416e5.png, the inequality https://upload.wikimedia.org/math/2/c/4/2c412a6f49514db4dbd890537413bcc6.png holds.
Taken from https://en.wikipedia.org/wiki/(ε,_δ)-definition_of_limit
The problem what Iam facing is the statement ," for all
in
that satisfy [PLAIN]https://upload.wikimedia.org/math/6/e/e/6ee6dc9ee03f04da6ff784b6eca416e5.png". Though I have understood this statement, this hinders my proving this property of limit
lim f(c+h)=L =lim f(x).
h->0 x->c
I am trying to prove the LHS from the RHS.
We know,
"the function f has a limit L at
is defined to mean
for every ε>0,there exists a δ>0, sucht that, for all x in D satisfying, o<|x-a|<δ, implies |f(x)-L|<ε.The LHS can be proven from the trivial fact taking
x-c=h.
A question arises to me. How do we know the existence of such an h? Also, for what all h does this inequality o<|h|<δ implies |f(c+h)-L|<ε hold?
You are taking h= x- c so "h goes to 0" is the same as "x goes to c" or [itex]|h|< \delta[/itex] is the same as [itex]|c+ h|< \delta[/itex]. In more detail, if [itex]|h|< \delta[/itex] then [itex]-\delta< h< \delta[/itex] so that [itex]-\delta< x- c< \delta[/itex] and vice-versa.
Likes Alpharup
How is this possible?
The fact is that you change variable but the limit remains the same, by assumptions you have ##\lim_{x\rightarrow c} f(x)=L## if you change variable, you can set as example ##x=c+h##, so when ##x\rightarrow c## you have ##h\rightarrow 0## and the limit become:
##\lim_{h\rightarrow 0} f(c+h)=L## ... , such ##h## exists (because the difference ##x-c## always exists and you call it with the letter ##h##), therefore ##0<|h|<\delta ## and from ##\left|f(x)-L\right|<\varepsilon## you have ##\left|f(c+h)-L\right|<\varepsilon## ...
It is only a way to rewrite the limit from the variable ##x## to the new variable ##h##, in fact ##c## is a number always fixed and I suppose finite ...
Likes Alpharup
@Ssnow
You are right. Such an h exists like h=x-c.
But what is the condition 'h' should satisfy? How do convert the statement "for all x satisfying 0<|x-c|<δ" to "for all h satisfying 0<|h|<δ"
Other statements in the epsilon-delta definition make sense except this statement. Can we convert from "all x" to "all h"?
Likes Ssnow
Yes, now you point is ##0## so for all ##h## satisfying ##0<|h-0|<\delta## ...
Likes Alpharup
Oops! I meant to write [itex]|h|< \delta[/itex] is the same as [itex]|x- c|< \delta[/itex].
Likes Alpharup
Yes, logically it is right. But, i need conversion of statement. I thought of this proof. Please say whether it is right.
All the numbers are real in this discussion.
Because of exsistance property of h for any real numbers x and c, we can write:
For all real x and all real c, there exists an unique(one and only one) h such that h=x-c.
Let us take an x which satisfies 0<|x-c|< δ. Let it be x1. By definition, we have "for all x satisfying the property P". So, we can take an arbitray x =x1 satisying that property.
For this x1 and c, we have an unique h=h1 such that h1=x1-c.
By induction,we can prove that for a xn(satisfying P) and c, we have an unique hn such that hn=xn-c.
x can be x1,x2...xn(which satisfying P)
h can be h1,h2,...hn(which are unique for a given x).
So, by induction we can say, "for every x, we can find, every h."
yes, but I think the existence it is clear because ##x,c## exists so also the difference exists in ##\mathbb{R}##. To prove the unicity of ##h## you can procede by contradiction argument. Assume that there are two ##h_{1},h_{2}## such that ##h_{1}=x-c## and ##h_{2}=x-c##, then it is clear that ##h_{1}=h_{2}##, so is unique ...
Likes Alpharup
Good proof of uniqueness theorem...
Likes Ssnow
Related to Epsilon-Delta definition property.
1. What is the Epsilon-Delta definition property?
The Epsilon-Delta definition property is a method used to precisely define the limit of a function. It is commonly used in calculus to rigorously prove the convergence of a sequence or the continuity of a function.
2. How does the Epsilon-Delta definition property work?
The Epsilon-Delta definition property states that for a given function f(x), if a limit L exists at a point x=a, then for any positive number ε (epsilon), there exists a positive number δ (delta) such that when the distance between x and a is less than δ, the distance between f(x) and L is less than ε. This can be written as |f(x) - L| < ε when 0 < |x-a| < δ.
3. Why is the Epsilon-Delta definition property important?
The Epsilon-Delta definition property is important because it provides a rigorous and precise way to evaluate limits and prove the continuity of functions. It also allows for a better understanding of the behavior of functions near a specific point.
4. What are some common mistakes when using the Epsilon-Delta definition property?
One common mistake when using the Epsilon-Delta definition property is not choosing the appropriate ε and δ values. If the chosen values are too large, the proof may not hold, and if they are too small, it may be difficult to find a suitable δ value. Another mistake is not considering all possible cases, such as when x is less than or equal to a.
5. How can I practice using the Epsilon-Delta definition property?
One way to practice using the Epsilon-Delta definition property is to solve exercises and problems that require the application of the definition. You can also try to prove the convergence of different sequences or the continuity of various functions using the Epsilon-Delta definition property. Additionally, studying and understanding the properties and theorems related to limits and continuity can also help improve your understanding and application of the Epsilon-Delta definition property.
  • Calculus
