Epsilon-Delta proof. Have I done it right?
  • Thread starter MrGandalf
  • Tags
    Proof
In summary, we proved that if f and g are continuous functions, then so is fg, defined as (fg)(t) = f(t)g(t) for all t in a subset E of an ordered field F. This was done by taking three delta-values, one for each factor and using the triangle inequality to bound the difference between (fg)(x) and (fg)(a). We also made sure to handle the case where |g(a)| is zero by adding 1 to the denominator in one of the delta expressions. This completes the proof.
MrGandalf
30
I'm going to prove that if f and g are continuous functions, then so is fg.
We define [itex]fg \; :\; E \rightarrow \bb{F}[/itex] by
[itex](fg)(t) \;=\; f(t)g(t)[/itex] for all [itex]t \in E[/itex]
(F is an ordered field and E is a subset of F).
Proof
[tex]|(fg)(x) - (fg)(a)| = |f(x)g(x) - f(a)g(a)| =[/tex]
Add and subtract f(x)g(a)
[tex]|f(x)g(x) - f(x)g(a) \;+\; f(x)g(a) - f(a)g(a)| \leq [/tex]
We use the triangle inequality
[tex]\leq |f(x)g(x) - f(x)g(a)| \;+\; |f(x)g(a) - f(a)g(a)| = [/tex]
We factor out f(x) and g(a)
[tex]|f(x)||g(x) - g(a)| \;+\; |g(a)||f(x) - f(a)|[/tex]
From the definition pf continuity we have
[itex]\delta_1[/itex] such that [itex]|f(x) - f(a)| < \frac{\epsilon}{2}[/itex] for [itex]|x-a|[/itex]
[itex]\delta_2[/itex] such that [itex]|g(x) - g(a)| < \frac{\epsilon}{2}[/itex] for [itex]|x-a|[/itex]
But we still have |f(x)| and |g(a)|.
From the definition, we can deduce [*] - This part I'm not really sure about.
[tex]|f(x) - f(a)| < \frac{\epsilon}{2} \;\Rightarrow\; |f(x)| < \frac{\epsilon}{2} + |f(a)| [/tex]
[tex]|g(x) - g(a)| < \frac{\epsilon}{2} \;\Rightarrow\; |g(a)| < \frac{\epsilon}{2} + |g(x)| [/tex]
And we can choose new delta-values:
[tex]\delta_3[/tex] such that [tex]|f(x) - f(a)| \;<\; \frac{\epsilon}{2(\frac{\epsilon}{2}+ |f(a)|)}[/tex] for [tex]|x-a|[/tex]
[tex]\delta_4[/tex] such that [tex]|g(x) - g(a)| \;<\; \frac{\epsilon}{2(\frac{\epsilon}{2}+ |g(x)|)}[/tex] for [tex]|x-a|[/tex]
In conclusion, we take [itex]\delta_5 = \min(\delta_3, \delta_4)[/itex]
And get:
[tex]|f(x)||g(x) - g(a)| \;+\; |g(a)||f(x) - f(a)| <[/tex]
[tex](\frac{\epsilon}{2} + |f(a)|\cdot \frac{\epsilon}{2(\frac{\epsilon}{2}\cdot |f(a)|)}) + (\frac{\epsilon}{2} + |g(x)|\cdot \frac{\epsilon}{2(\frac{\epsilon}{2}\cdot |g(x)|)}) = \frac{\epsilon}{2} + \frac{\epsilon}{2} = \epsilon[/tex]
And the proof is concluded. Quad Erad Demonstrandum... if it is right, of course.
Hope it wasn't too long!
You factorized properly. Take a delta such that |f(x)-f(a)| < 1 as x -> a. Then you can get a bound on |f(x)|, say M. Then you choose another delta so that |f(x)-f(a)| < epsilon/(2|g(a)|+1). Then choose another delta such that |g(x)-g(a)| < epsilon/(2M). Then take the smaller of all three deltas, and you get your result.
You do need the fact that, since f is continuous, |f(x)| has an upper bound in order to handle the fact that |f(x)| is variable, not a constant like |g(a)|.
We now choose three [itex]\delta[/itex]'s, so
[tex]\delta_1[/tex] such that [tex]|f(x) - f(a)| < 1 \;\Rightarrow\; |f(x)| < M[/tex] (since f is continous, |f(x)| has an upper bound).
[tex]\delta_2[/tex] such that [tex]|g(x) - g(a)| < \frac{\epsilon}{2M}[/tex]
Obviously, [itex]|g(a)| < |g(a)| + 1[/itex]
[tex]\delta_3[/tex] such that [tex]|f(x) - f(a)| < \frac{\epsilon}{2(|g(a)| + 1)}[/tex]
In conclusion, we take [itex]\delta = \min(\delta_1, \delta_2, \delta_3)[/itex]
And get:
[tex](M\cdot \frac{\epsilon}{2M}) + (|g(a)| + 1\cdot \frac{\epsilon}{2(|g(a)| + 1)}) = \frac{\epsilon}{2} + \frac{\epsilon}{2} = \epsilon[/tex]
Thanks for the help!
To make the proof complete, you should explain that the +1 in epsilon/(2|g(a)|+1) is used because |g(a)| might be zero.
Also, you said "since f is continous, |f(x)| has an upper bound". Continuity alone is not enough, |f(x)| has an upper bound on what set? It certainly does not necessarily have an upper bound on R.
You can remove any doubt by getting an explicit expression for M in terms of f(a) by using the fact that |f(x)-f(a)| < 1 (which is easy). You see, |f(x)| is bounded not only because f is continuous but also because (a - delta1, a + delta1) is a subset of [a - delta1, a + delta1] and [a - delta1, a + delta1] is compact, but I don't think you should talk about this for this proof. Getting an explicit expression for M will remove any questions.
FAQ: Epsilon-Delta proof. Have I done it right?
What is an Epsilon-Delta proof?
An Epsilon-Delta proof is a type of mathematical proof used in calculus to show that a function satisfies a given limit. It involves choosing a small number, epsilon, and then finding a corresponding number, delta, such that as the input of the function approaches a certain value, the output of the function will be within epsilon of the limit.
Why is an Epsilon-Delta proof important?
Epsilon-Delta proofs are important because they provide a rigorous and precise way to prove that a function satisfies a given limit. They are also used to prove many other important theorems in calculus and real analysis.
How do I know if I have done an Epsilon-Delta proof correctly?
To ensure that your Epsilon-Delta proof is correct, you should follow the steps in the proof carefully and check that your chosen values for epsilon and delta satisfy the definition of a limit. You should also double-check your algebraic and logical steps to make sure they are correct.
What are some common mistakes made in Epsilon-Delta proofs?
Some common mistakes made in Epsilon-Delta proofs include using the wrong values for epsilon and delta, incorrect algebraic manipulations, and not fully understanding the definition of a limit. It is important to carefully check each step of the proof to avoid these mistakes.
Are there any tips for writing a successful Epsilon-Delta proof?
Some tips for writing a successful Epsilon-Delta proof include understanding the definition of a limit, choosing small and simple values for epsilon and delta, carefully following the steps of the proof, and checking your work for mistakes. It is also helpful to practice writing Epsilon-Delta proofs and seek feedback from others.
